Interior lights come on when using turn signals - JeepForum.com
post #1 of 5 Old 01-07-2010, 06:53 PM Thread Starter
kking08
2010 JK Wrangler
for whatever reason my interior lights come on only when using the left turn signal, usually after it clicks off the lights will go off or you need to mess with the dimmer switch until they go off. and it only does it with the left turn signal. any ideas on how to fix this its driving me crazy
kking08 is offline
post #2 of 5 Old 01-07-2010, 07:54 PM
JeepGuyBrian
2011 JK Wrangler
ha, that sounds like quite the situation.... and I'm sure you'd find it a little humorous too if wasn't your Jeep
Electrical problems mystify me, and drive me nuts... but I wish you the best of luck! I'm sure someone knowledgeable will chime in, maybe it is as simple as a fuse.
JeepGuyBrian is offline
post #3 of 5 Old 01-07-2010, 08:15 PM Thread Starter
kking08
2010 JK Wrangler
yeah its very annoying, also awhile back i removed the fuse behind the glove box so that the lights stay off when the doors are removed, not really sure if that would matter
kking08 is offline
post #4 of 5 Old 01-07-2010, 08:21 PM
Slithering_Joe
Those TJ models with the headlamps/dimmer/etc on the turn signal stalk:
I would bet from the motion of you switching your turn signal on the dimmer/courtesy lamps portion of the assembly is flexing which then turns on the interior courtesy lamps. Weird but possible. The dimmer/courtesy lamps switch is part of the Multi-Function Switch (MFS) assembly. The dimmer/courtesy lamps switch sends a signal to the instrument cluster control module (RED wire). Then the instrument cluster control module provides ground (YELLOW wire) to control (on/off ) the interior lamps.
4.0L TJ
Slithering_Joe is offline
post #5 of 5 Old 01-08-2010, 07:12 AM Thread Starter
kking08
2010 JK Wrangler
thank you for the info
kking08 is offline
no dash lights or turn signals??? bigman7878 TJ Wrangler Technical Forum 2 02-16-2009 02:49 PM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
Need Help, Brake lights/turn signals Bugz2oo2 TJ Wrangler Technical Forum 5 08-29-2006 01:56 AM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
No turn signals or Brake lights Patton TJ Wrangler Technical Forum 1 09-10-2002 06:45 AM
