interior door plastic broken/cracked - JeepForum.com
post #1 of 5 Old 12-08-2008, 01:43 PM Thread Starter
Trebor
yestorday i replaced my hard top and it was windy and cold as i completed the task at hand, i noticed the driver side interior door plastic broken/cracked about 4 inches long aprox. five inched from the front of the door at the top and straight down. my concern is that it will continue to spider much like a windshield would, has anyone ever done a repair on the plastic? if so what did you use and how did it work out? thanks.
Bobby T...Out!!!
Trebor is offline
post #2 of 5 Old 12-08-2008, 01:44 PM
JTruel
To keep the crack from getting worse, remove the door panel and drill the end of the crack with a 1/4" drill bit.
2000 XJ Classic
2005 LJ
JTruel is offline
post #3 of 5 Old 12-08-2008, 01:46 PM
DixiesCJ3B
I would remove it, sand it down a little bit and then put epoxy on the back side of the crack, you will still be able to see the crack, but it wont get any worse
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline
post #4 of 5 Old 12-08-2008, 06:22 PM
2003RubiBlue
Same thing happened on my jeep on both sides. Just drill a small hole at the bottom of the crack to stop it from traveling. Thats all I did and its been almost two years. Then if it still bothers you, you can do what DixiesCJ3B says.
2003RubiBlue is offline
post #5 of 5 Old 12-08-2008, 08:41 PM
RiponredTJ
Happy Member No. 1
RiponredTJ's Avatar
I've have the exact same crack in my panel since I bought it. It hasn't travelled at all, but I like the idea of drilling a small hole as a preventative measure.
I'll be doing that once the weather warms up in about 5 months, or maybe sooner if I notice it getting worse.
I figure epoxy on the back of the panel to hold it all together, and some kind of plastic panel repair kit on the outside should make it as good as new.
http://www.plastex.ca/default.asp
Unless of course I can just find an intact gray panel at a scrap yard to throw on there.
This City is what it is because our citizens are what they are.
RiponredTJ is offline
BROKEN PLASTIC- Warranty?? armartel TJ Wrangler Technical Forum 9 12-23-2009 08:59 PM
Interior plastic repair TheBoogieman TJ Wrangler Technical Forum 3 01-19-2009 05:53 PM
How do you remove interior door plastic panel from 2007 JK? Redox JK Wrangler Technical Forum 16 05-13-2008 10:29 PM
Junk Plastic Interior juiceparn JK Wrangler Technical Forum 15 07-28-2007 01:32 PM
Repairing cracked plastic tcf26 YJ Wrangler Technical Forum 9 07-27-2003 09:00 PM
