Interior Door Panel Removal - JeepForum.com
post #1 of 7 Old 10-04-2003, 06:44 PM Thread Starter
rock2r
What's the tricks to removing the interior door panel (pass side) from the door assy? I want to pop a dent out that's been there from the previous owner. I got as far as removing the window crank and closure pull strap. I then tried to peek inside from the bottom to see what holds it all together. I saw some sort of "white nylon" fasteners....I think. I tried a little bit of prying apart, but nothing budged. Anyhow..thought I'd ask before I broke something. I do not have a service manual. It's a '98 Sahara, if that makes a difference. Thanks in advance.
2004 Rubicon-Bright Silver(Auto/Dual Tops)
8000 lb Warn Winch
Stowmaster 5000
Smittybuilt Neoprene Seat Covers (Blk/Blk-yet to fade!)
Jeeperman Rock Skidz-Herculined "for her pleasure"!
"Tough Stuff"- Fender, Door & Grill Protectors
rock2r is offline
post #2 of 7 Old 03-18-2004, 01:12 PM
samsammy23
How did you get the window crank off? I can't get this off?
Thanks.
Chad.
samsammy23 is offline
post #3 of 7 Old 03-18-2004, 01:27 PM
slabb42
slabb42's Avatar
Thanks.
Chad.
the window crank comes off easily with the right tool, go to your local auto parts store, and look for the "help!" tools, and replacement parts, there is a wierd fork looking tool, that is it. you need to push it behind the window crank to pop out the retainer clip (also known as the "oh -=-=-=-=-=-=-=-=" clip because it usually goes flying across the garage!) cup your hand around the post of the crank while doing this to prevent the clip from getting airborne.
here is the snap-on version of this tool, so you have an idea of what it looks like:
http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
as far as the door panel goes, i believe it is held in by nylon fasteners. if you do not use a panel tool to pop them, and you use a screwdriver, etc, you run the risk of breaking the fastener, or worse, your door. they are in there tight, so go to sears, and get a "tack puller" (located with the screwdrivers, and awls) or if you can find a prybar with a forked end, that will work too. I use a snap-on panel tool made for this type of job, but it was expensive (around $23) http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
'03 Rubicon
slabb42 is offline
post #4 of 7 Old 03-18-2004, 01:33 PM
roofdown
Those "white nylon fasteners" are holding the skin on. I believe they make a "special tool" for them, but you don't need it. Just get a big flathead screwdriver, slide it in right near the fastener, and then gently twist the driver. Fastener should pop out (it's just a plastic screw-like fastener that wedges itself in there). Repeat the process for the remaining fasteners (there are a few of them). To reinstall, just line up fastener w/ the appropriate hole, and give the door skin a good hit (should seat itself).
roofdown is offline
post #5 of 7 Old 03-19-2004, 09:48 AM
samsammy23
I bought that special tool for $5 at Azone. The clip did go flying across the garage. Good call and thanks. Once again, the right to for the job seems to work much better.
Chad.
post #6 of 7 Old 03-19-2004, 10:10 AM
Dragonmaster
Dragonmaster's Avatar
I just use a regular dinner fork with the centre two tongs cut out, works wonders.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
post #7 of 7 Old 03-19-2004, 05:19 PM
slabb42
slabb42's Avatar
Chad.
i told you that it would go flying! did you say "oh *****" when it did? that is why we call them "oh $-=-=-=-=-=-=-=-= clips"
'03 Rubicon
slabb42 is offline
Half door interior panel hole? popeyesides TJ Wrangler Technical Forum 4 08-01-2009 07:12 PM
Half door interior panel bfr TJ Wrangler Technical Forum 1 01-20-2009 04:41 PM
Interior Front Door Panel Removal? YoungTurk JK Wrangler Technical Forum 2 04-03-2007 08:25 PM
Interior Door Panel Removal? rock2r TJ Wrangler Technical Forum 3 06-16-2005 11:24 AM
where to get TJ interior door panel? gnetcanada TJ Wrangler Technical Forum 5 07-06-2004 11:54 AM
