Intelligent Question About Death Wobble - JeepForum.com
post #1 of 114 Old 06-25-2013, 10:24 AM Thread Starter
OzzLee
I know what you're thinking, not ANOTHER thread about DW. Don't worry, this isn't the usual "OMG what's going on" post.
I've spent the past week reading up on the infamous DW. I've read the forums and the article in the recent JP magazine, and what I gather is its like an old strand of christmas lights...one light fails and it mucks up the entire system. That and steering stabilizers only mask the problem.
My question: has anyone noticed if the wobble is brought on in different ways by different parts going bad. For example, if wobble from hard breaking or acceleration points to a different faulty part than wobble brought on by a bump in the road?
I ask because I can't make my Jeep shake if I try. I drive fast, slow, swerve, run over bumps, and anything else that would get me pulled over for reckless driving and the Jeep drives smooth and straight as an arrow. Then a few days later, driving casually on a relatively smooth road that I traverse on a daily basis, it shakes. I turn around and try to recreate the event.....no wobble.
When I have a free weekend, my step-dad and I will check all the joints and bolts and what not. I'm confident we can find the chink in the system.
OzzLee is offline
post #2 of 114 Old 06-25-2013, 10:36 AM
SlackJaw
baby jeep
SlackJaw's Avatar
First, do you have teh shimmy or the Death Wobble?
I remember hearing tale that you could tell under certain conditions if it might be your control arms....under braking v accel, and/or possibly in 4wd or not. I tried all these and couldn't perceive much of a difference....and it ended up being my CAs anyway. If you've got no wobble, but when you brake you do, then I would say it's likely you have runout on a rotor or "warped" in layman's terms...but if that's throwing you into full blown death wobble, you probably have other issues.
The methodology should be this:
Make sure your tires are balanced well and do not have uneven wear. Make sure your toe is correct. Check wheel bearings and ball joints. These are all easy checks and should be done regularly when you rotate tires anyway.
Do a dry steer test. This is also an easy test, but is typically only run if something doesn't right. Look particularly at the trac bar, but certainly all the other joints.
If all this checks out, then it's your control arms. This is usually the last check, as it is more difficult to confirm, but really, if everything else is good, this will be it. If you have 10+ years on the stock ones, it's a fair bet they are toast anyway, and I'd put even more odds on these if you are lifted.
I also had some intermittance when mine first started shimmying...kind of like you are referencing, like it would wobble all the time, but then if I wheeled it (flexing it out), the trip home would be smooth as glass. Again, final determination in my case was that it was my CAs. Another test I happened to do, (after my D/W became full blown) was to take the lift off the front. D/W was gone. Put the lift back on, D/W was present.
SlackJaw is offline
post #3 of 114 Old 06-25-2013, 10:39 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
It's all the same and if you get DW,you'll know it and be changing your underwear quickly.I've had unblanced tires or uneven tire wear cause an occassional wobble,but not DW.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #4 of 114 Old 06-25-2013, 10:49 AM
TheBoogieman
Originally Posted by SlackJaw View Post
I remember hearing a tale
Me too.Was it a tale of a fateful trip
That started from this tropic port
Aboard this tiny ship?
post #5 of 114 Old 06-25-2013, 11:08 AM
J03_TJ
I've used the passenger test to determine I I had DW. Make sure they are only used to driving/riding in cars with good suspension characteristics. Have them ride along on a road that will trigger your wiggle. If they grab the bar above the glove box and look at you really scared, you probably have DW.
J03_TJ is offline
post #6 of 114 Old 06-25-2013, 11:12 AM
TheBoogieman
But if it's a girl with bladder problems,you have to clean the pee off your seats.(Don't ask how I know that one.)
post #7 of 114 Old 06-25-2013, 11:51 AM
J03_TJ
Funny. Me and a buddy went hunting one day in mine a few years back when I was having DW problems. I'd have to say he is my most "redneck" friend, doesn't mind fighting, chews and doesn't spit, all round tough guy that I wouldn't think would be scared of anything. He was scared the whole ride home after it happened. Not me though having been through it a few times.
J03_TJ is offline
post #8 of 114 Old 06-25-2013, 12:29 PM
matteo92065
Ozzlee, I feel your frustration/pain.
My DW is also very intermittent. I really think that mine is most evident when it is cooler out and the jeep (and tires) are cool. [run on sentence] I go up a hill in the morning and the thing will shake the hell out of everything, have to pull over and get it under 10mph, catch my breath, turn around to go home and put it in the garage and take the VW to work [/run on sentence]. BUT, on the way home the thing is smooth as can be. So I turn around AGAIN, head up the hill and all is good and almost perfectly smooth! What gives?
My build up:
2005 Jeep Rubicon
matteo92065 is offline
post #9 of 114 Old 06-25-2013, 12:31 PM
biffgnar
biffgnar's Avatar
Wasn't Blaine once upon a time trying to collect info to use onset speed as an indicator of where the problem was? Maybe I am misremembering.
biffgnar is offline
post #10 of 114 Old 06-25-2013, 12:38 PM
SlackJaw
baby jeep
SlackJaw's Avatar
sort of...between 47 and 53 iirc his last statement on it, but that's where it starts for everyone...I mean the oscillation of the axle is what it is, regardless of what starts it.
SlackJaw is offline
post #11 of 114 Old 06-25-2013, 12:38 PM
JEK3
JEK3's Avatar
Originally Posted by matteo92065 View Post
... I really think that mine is most evident when it is cooler out and the jeep (and tires) are cool...
I noticed a temperature dependence with mine also. I believe it is because the CA bushings are stiffer when they're colder.
JEK3 is online now
post #12 of 114 Old 06-25-2013, 12:38 PM
SlackJaw
baby jeep
SlackJaw's Avatar
pics please.
SlackJaw is offline
post #13 of 114 Old 06-25-2013, 12:39 PM
SlackJaw
baby jeep
SlackJaw's Avatar
this. Except mine was the other way around...warmer it got, more it shimmy. This seems to make more sense to me considering the properties of rubber.
SlackJaw is offline
post #14 of 114 Old 06-25-2013, 12:49 PM
matteo92065
I'm running all JJ's on control arms.
Yes on the speed. "Magic speed" is right around 50mph. I can keep it just under the magic speed and it is like tires are out-of-balance. But if I immediately try to 'power' through the shake it will get worse and develop into DW. If I wait a few minutes at just below the magic speed then 'ease-into-it' I can get up to 60-70 mph with no drama.
My build up:
2005 Jeep Rubicon
post #15 of 114 Old 06-25-2013, 01:55 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Push it past 70 and you should be able to find another magic speed for a even wilder ride
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
death wobble
