Intake manifold dirty, how should i clean it? - JeepForum.com
post #1 of 17 Old 06-17-2010, 03:08 PM Thread Starter
patricknolan
As stated, my intake manifold is dirty. Seems to have some oil in there as well as sludge buildup along the sides. Im young and haven't the experience to know if this is normal in vehicles, or if it is cause for concern and I should clean. Is there any good ways to clean it besides removing and just spraying it with carb cleaner?
patricknolan is offline
post #2 of 17 Old 06-17-2010, 03:40 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I'm assuming your speaking of the inside?Unless you want to do it the best way by pulling the intake, then all you can do is purchase throttle body spray cleaner and go at it.
GOLENJEEPTJ is offline
post #3 of 17 Old 06-17-2010, 03:45 PM
Chilly
You need a can of throtle body cleaner, rag, Q-tips, screwdriver, chair, and a beer. Remove the throtle body from the motor and clean it. Takes about 15 minutes so you might need more than one beer
05 Unlimited 3" lift, 33" MT MTZ so far
Chilly is offline
post #4 of 17 Old 06-17-2010, 03:49 PM
JohnF
He said he was young. He may have to wait until he's 21 to do the job
JohnF is offline
post #5 of 17 Old 06-17-2010, 03:52 PM
Chilly
Hell I had my first beer years before I had my first car lol but I guess that's how we rolled back in the day.
Chilly is offline
post #6 of 17 Old 06-17-2010, 03:54 PM
1jack5
do not use carb cleaner, Throttle body cleaner only. Sea foam works good too. Crank the car and wait about 5 mins then pour into intake, at first you will think you just blew up your car because it will smoke like a Cuban with a cigar but it will do its cleaning job and make you Jeep run a lot better.
1jack5 is offline
post #7 of 17 Old 06-17-2010, 03:55 PM Thread Starter
patricknolan
Yes I will be pullnig it anyway to check for cracks on my exhaust manifold. Ill use the advice below for cleaning the throttle body and the intake.
Well i guess I have to wait about 2 and a half more months before i can do this job!
I actually already seafoam'd it last week. I didnt get much, if any smoke. It was more like someone smoking a cigarette at best. But I believe that is because my CAT may be clogged, which is a another project another day. Right now I am checking my exhaust for leaks first, which is why my intake and exhaust manifolds will be off.
post #8 of 17 Old 06-17-2010, 04:16 PM
Zackb911
Zackb911's Avatar
I have a cat for sale in the classifieds cheap
Zackb911 is offline
post #9 of 17 Old 06-17-2010, 04:44 PM
Shinitenshi
1997 Jeep Wrangler SE 4x4
Low output 4 Cylinder Jeep Club Member #0492
Shinitenshi is offline
post #10 of 17 Old 06-17-2010, 05:13 PM
Strizzy
Are you running a stock air filter or K&N?
Strizzy is offline
post #11 of 17 Old 06-17-2010, 05:26 PM
GOLENJEEPTJ
I've had my intake off going on 6 times!It's a piece of cake, if it's that dirty..... to do it like that and do it right!
post #12 of 17 Old 06-17-2010, 05:59 PM
Chilly
I also removed everything I could off the throtle body to help get into all the little holes.
Chilly is offline
post #13 of 17 Old 06-17-2010, 06:15 PM
Shinitenshi
I have stock air filter oh and don't forget to pull those sensors off before u clean >.< once you figure out how to take it off omg really easy! 10min job
post #14 of 17 Old 06-17-2010, 06:54 PM Thread Starter
patricknolan
Im talking about the intake manifold.... not the throttly body. Its definitely not a ten minute job to remove that and clean it. Taking the throttle body off is a piece of cake.
Anyway, does everyone else have their brake lines (i think there brake lines) sandwhiched between a piece of sheetmetal that is bolted into the bottom of their intake manifold? I have this twice. These bolts are 9 mm and are stuck pretty good. Broke 1 socket adapter already and neitheer are even loose.
Also, anyone know what http://www.dailydriventj.com/images/mfr/43.jpg that is? the guide im using [Repair] Exhaust Manifold Replacement Guide says on step 12 to undo these bolts. I couldnt find them...
post #15 of 17 Old 06-17-2010, 07:14 PM
fire239
Your 97 may not have that piece..
fire239 is offline
Changing intake manifold and exhaust manifold Gaskets Cards89YJ YJ Wrangler Technical Forum 17 01-13-2012 04:32 PM
How can I clean out my intake manifold? citRon YJ Wrangler Technical Forum 2 07-29-2008 07:02 AM
Installed 4.0L TB, 62mm Spacer, High Flow Intake, and bored out intake manifold... micfly83 YJ Wrangler Technical Forum 35 08-21-2006 05:32 PM
Dirty intake and exhaust ports bigstinger YJ Wrangler Technical Forum 2 06-27-2006 08:23 AM
how can i clean the dirt out of the intake manifold?? RnEmOvr TJ Wrangler Technical Forum 2 09-26-2005 06:39 PM
