Instrument Cluster problems - JeepForum.com
post #1 of 6 Old 10-16-2003, 03:04 PM Thread Starter
Freakshow
Freakshow's Avatar
Don't I have the best luck; my wife can buy any vehicle she wants with no trouble, but anything I buy will have a plethora of problems. I just purchased my first Jeep , but now the instrument cluster is going crazy. Sometimes it works, sometimes it doesn't. I spoke with both the dealer I bought the Jeep from, as well as Chrystler, and they both said its a known issue that a $12 part might fix. MIGHT. If this patch doesn't take care of it, they said I'll need to replace the whole cluster.
Anyone else encounter this problem?
Freakshow is offline
post #2 of 6 Old 10-16-2003, 03:33 PM
CoryB
CoryB's Avatar
2015 JK Wrangler
Yep. The fix can be found at http://www.jeepmadness.com/guages.htm
CoryB is offline
post #3 of 6 Old 10-16-2003, 05:26 PM Thread Starter
Freakshow
Freakshow's Avatar
Thanks a bunch.
post #4 of 6 Old 10-16-2003, 09:42 PM
JTJ98
JTJ98's Avatar
I had this EXACT problem with my 98 TJ. You should not have to replace your cluster. The part the dealer will give you is a new plug, go get it. Splice in the new wires and plug it in. The cluster will work if you did it right! I did this and have not had a problem with the cluster since. Bending the pins is just ridiculous in my opinion. Good luck!
JTJ98 is offline
post #5 of 6 Old 10-18-2003, 09:40 PM
Dr.Jeep
There was a call back on that problem.My 1999 Sahara did it.All I did was take the trim off from around the cluster and removed the cluster mount screws and unplug and plug the cluster back in a few times.Doing that cleans the harness connections.
Dr.Jeep is offline
post #6 of 6 Old 10-19-2003, 03:36 PM
blksahara
This exact same problem arose for me w/ my 99 Sahara about 6 months ago. Started out rare and gradually started happening about every time I drove the Jeep (all of this in about a 3 week period). I did the fix as stated above (http://www.jeepmadness.com/guages.htm) and have NOT! had a problem since
.....plus I did the fix AT WORK on my dinner break. lol. Took less than 20 minutes and needed nothing but a screwdriver and a pair of needle nose pliers!
1999 Black Sahara:
2" Tera BB w/ DT 3000's
31x10.50 GY MTR's on stock Canyons
blksahara is offline
electrical problems w/ instrument cluster 2005 rs301801 TJ Wrangler Technical Forum 1 01-19-2009 06:01 AM
Help with my instrument cluster!! Bwesley TJ Wrangler Technical Forum 3 03-10-2008 05:13 PM
'91 instrument cluster Sambox YJ Wrangler Technical Forum 5 03-06-2007 09:19 PM
instrument cluster problems tjboy TJ Wrangler Technical Forum 2 11-11-2005 10:07 PM
Instrument cluster tjboy TJ Wrangler Technical Forum 3 10-19-2005 09:48 PM
