Installing transmission: to install transmission and t-case as a unit or separately? - JeepForum.com
post #1 of 9 Old 10-03-2009, 11:21 AM Thread Starter
Arron
Im getting ready to put my transmission back in and was wondering which would be easier? To install the transmission first then put the transfer case on or to install them as a unit?
While taking it out i removed both as a unit and it was fairly awkward.
Also if anyone has access to jeep part numbers im looking for the two reverse torques bolts that hold the top of the transmission bell housing to the engine block. I stripped one while removing the trans. (might replace with regular hex head instead of replacing with reverse torques)
Arron is offline
post #2 of 9 Old 10-03-2009, 11:29 AM
Red_
2016 KL Cherokee
I found separately was easier
Red_ is offline
post #3 of 9 Old 10-03-2009, 11:36 AM
Stu Olson
Stu Olson's Avatar
I've done it a couple of times and did them separate. I've never done them together but I can't imagine it being easier.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #4 of 9 Old 10-03-2009, 11:37 AM
cmoore
cmoore's Avatar
if it was me, separate.
98 XJ:4.0, AW4, HP30/8.25 4.56 Spartan/LSD, alloy shafts & joints, HD steer, SYE/CV, skids, RADesigns gated shifter, RE mix n match lift, 35"mt/rs, THOR guards F&R, weld-in custom rockers & stiffeners, custom front bumper, orfab rear bumper, THOR cowl induction, on board air, on board welder, etc
cmoore is offline
post #5 of 9 Old 10-03-2009, 02:10 PM
dodgetk81
Seperate is easier for me. I would not replace the external torx bolts. Get regular hex heads.
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
post #6 of 9 Old 10-03-2009, 02:21 PM
incredibull
Separately for sure. It's nearly impossible to get everything aligned with both as a unit unless you have a transmission jack.
incredibull is offline
post #7 of 9 Old 10-03-2009, 03:34 PM
BlueFlame
BlueFlame's Avatar
I've never done a TJ, but I've done a dozen or so other 4x4s and together was far easier.
Never tried it without a transmission jack. You can rent a transmission jack for cheap, save you dropping heavy stuff on your head.
BlueFlame is offline
post #8 of 9 Old 10-03-2009, 03:43 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Definitely do them separately...
Knuckelhead is offline
post #9 of 9 Old 10-03-2009, 04:10 PM
aubieron
Just put my trans back in this morning. Took five-and-a-half hours start to finish, including clean up and putting tools away. I used two tranny jacks and put both in as a single unit. Way too easy.
War Damn Eagle!
aubieron is offline
Compression T-Fitting for Auto Transmission Sending Unit Leaking JeepnAZ TJ Wrangler Technical Forum 3 01-24-2009 08:39 PM
problems installing auto transmission pwcracer TJ Wrangler Technical Forum 7 04-30-2008 09:49 AM
33's and a sending unit (32rh transmission) HowIRoll TJ Wrangler Technical Forum 14 04-18-2008 08:44 AM
HELP... Transmission (transfer case?) shiften left while installing MML ixl4 TJ Wrangler Technical Forum 3 05-06-2005 07:54 PM
Installing Clutch...Can't Pull Transmission bigsteve3184 YJ Wrangler Technical Forum 11 03-23-2003 09:18 PM
