Installing Superlift Tru-speed - JeepForum.com
post #1 of 4 Old 06-27-2006, 04:29 PM Thread Starter
rockhi
rockhi's Avatar
For those that have installed the Superlift Tru-speed Modual ....where did you install the actual unit? was the install fairly simple? any comments ? Thanks
2006 Rubicon unlimited--6 speed--4" Skyjacker lift- AR Wheels 16x8-MT Baja claw 33x12.50- Jeeperman Frt. & Rear Bumpers- -Rock Crusher Diff. covers X2 -Powertank CO2-
rockhi is offline
post #2 of 4 Old 06-27-2006, 08:09 PM
AZSahara
AZSahara's Avatar
The install is very straightforward. Splice into the wires coming off the sending unit and hook up 12 volts and a ground. You can drill a hole in the tunnel above the sender and insert a grommet to run your wires through and you can put the unit anywhere in the cabin where you can get 12v. I actually ran the wires under my console and up into the glove box. Makes it real easy to get to when it comes time to calibrate.
John
L92/6L80 98 TJ
From the wilds of Northern Arizona
AZSahara is offline
post #3 of 4 Old 06-28-2006, 03:56 AM Thread Starter
rockhi
rockhi's Avatar
Thanks John..where did you tap into the hot wire on yours?
again thanks
rockhi is offline
post #4 of 4 Old 06-28-2006, 11:08 AM
eastieboy96
I went right down through my shifter to get the feed from the speedo harness. Velcro ed the tru-speed unit up above the travel of the glove box, leaving the switch exposed but easily can take down to calibrate. I think I tapped my cig lighter for my hot and got a local ground.
Just a tip on calibrating, use the percentage of change chart rather than tire or gear charts to make adjustments. This will get you super close to 100%. I check mine with the highway markers and was damn close.
eastieboy96 is offline
Installing Speed Control Kit larryma JK Wrangler Technical Forum 7 03-30-2009 05:48 PM
will a 95 cherokee np231 from a 4.0 5 speed fit on my 99 wrangler sport 5 speed? subzeroedj TJ Wrangler Technical Forum 2 08-15-2008 09:35 AM
2.5 liter speed ?. Cruise speed 33'12.5" ironwoodsmith TJ Wrangler Technical Forum 10 05-31-2006 01:28 PM
Where to purchase Superlift TruSpeed Speed Sensor Recalibrator JeepRocks86 TJ Wrangler Technical Forum 10 04-15-2006 11:53 AM
Anyone kno nething about the 4 speed auto? What year start useing? bolt into 3 speed? jeepcj7 TJ Wrangler Technical Forum 6 06-23-2004 08:33 AM
