Installing a soft top - JeepForum.com
post #1 of 12 Old 03-15-2011, 08:35 PM Thread Starter
snowboarder87
Ive done some searching on how to install a soft top but Ive had no luck. Its getting warm out and its time for the hard top to go. However, this is my first time putting up the soft top and Im having a hard time installing all of the brackets for the top. Does anyone have any pictures or instructions on how to set up the brackets or "cage" for the soft top?
snowboarder87 is offline
post #2 of 12 Old 03-15-2011, 08:49 PM
2jhanna
you will need door surrounds along with 4 knobs, should be self explanatory.
roll bar brackets with 2 mounting screws for each side. these mount underneath the padding, below and to the rear of the front seat belt mounts. there should be slits in the padding.
brackets for the tail gate bar. mounted to the left and right side tail gate on the tub.
do you have this stuff ??
jhanna
denton county, tx
2jhanna is offline
post #3 of 12 Old 03-15-2011, 08:49 PM
hustler905
Check YouTube, someone converted the video version of the owner's manual
hustler905 is offline
post #4 of 12 Old 03-15-2011, 09:09 PM
wadup45
what soft top do you have, factory or aftermarket??
wadup45 is offline
post #5 of 12 Old 03-15-2011, 09:23 PM
Redz72
Redz72's Avatar
Figure out what type of top you have and either check the manual, or the manufacturer's website.
BLACK JEEP SOCIETY #218
Redz72 is offline
post #6 of 12 Old 03-16-2011, 07:28 PM Thread Starter
snowboarder87
Its the OEM soft top. When I bought the Jeep it came with a hard top and a soft top, both stock. Ive had the hard top on up until yesterday, and now that its getting warmer its time for the soft top.
post #7 of 12 Old 03-17-2011, 10:18 AM
Neil F.
Neil F. is offline
post #8 of 12 Old 03-20-2011, 12:33 PM Thread Starter
snowboarder87
alright thanks, ive seen that video before but ill definitely have to check it out again
post #9 of 12 Old 03-20-2011, 12:48 PM
Jeffro06
Jeffro06's Avatar
I hope you have a heated garage, because there's no way it's even close to warm enough (in WI) to install a soft top.....it'll shrink in the cold weather and make getting it on impossible.
Jeffro06 is offline
post #10 of 12 Old 03-20-2011, 01:19 PM
cruechief
Yeah need to get the material over 70 degrees before it will stretch enough to work with
98 XJ 4 1/2 RE on 32" big at
04 WJ limited v8
13 WK2 Overland 5.7
97 tj-Sold
cruechief is offline
post #11 of 12 Old 03-20-2011, 02:05 PM
R U STUCK
This is true. You will get frustrated and put the hard top back on. I put mine on in the first week of May. Because I can barely lock the soft top at night from it cooling down. I still have the VHS tape for top operation from when I bought this one new in '04.
'04 TJ Rocky Mountain, 4" Fabtech, Sitting on 35"s
Jeep Selling Guru...
IG: R_U_STUCK
R U STUCK is offline
post #12 of 12 Old 03-22-2011, 04:47 PM Thread Starter
snowboarder87
thanks for all the advice
i havent messed with the soft top yet, i have only taken the hard top off because it got up to 60 degrees recently. overall, i finally have a general idea of how the brackets are supposed to be set up, now i guess i have to wait for the warmer weather haha
brackets , hard , install , soft , top
Installing a new soft top, well new to me! 07BlackOps JK Wrangler Technical Forum 2 03-03-2011 04:46 PM
Help installing soft top xamdarb TJ Wrangler Technical Forum 3 03-01-2009 01:51 PM
Installing New Soft Top JeffsGP JK Wrangler Technical Forum 1 07-29-2008 11:29 AM
Installing Soft Top FloodCity 01 TJ TJ Wrangler Technical Forum 1 04-30-2007 07:22 AM
Installing soft top Jeepthing88 TJ Wrangler Technical Forum 8 06-19-2006 01:55 PM
