Installing Rokmen Sliders-Tips Please - JeepForum.com
post #1 of 4 Old 07-02-2010, 04:38 PM Thread Starter
explorerlyon
explorerlyon's Avatar
I am installing my Rokmen rock sliders this weekend. Need a few tips please:
1. I am removing the existing factory Rubicon rocker guards. What should I do, if anything, with the existing holes?
2. Somewhere way back I remember reading to "pre-tension" the sliders to the body. How is this done? Put a jack under the slider and lift the body slightly so the slider is tight as can be against the body?
3. Any other tips for a good install?
Thanks
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #2 of 4 Old 07-02-2010, 05:17 PM
F9K9
F9K9's Avatar
Originally Posted by explorerlyon View Post
...........I am removing the existing factory Rubicon rocker guards. What should I do, if anything, with the existing holes?
Nada, zip, nothing
Just make sure the sliders are snug when you mark for drilling or drill. Smooth out the rough edges of the freshly drilled hole and paint the bare metal. Spraying rattle can paint into it's cap and using a "Q tip" for applying the paint is my method.
Outside of that, just expect a bunch of different opinions.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #3 of 4 Old 07-02-2010, 06:02 PM
wushaw
Rockin jeep
wushaw's Avatar
Blind nuts/riv nuts for the bottom bolts instead of having a nut & shank through the floor?
wushaw is offline
post #4 of 4 Old 07-02-2010, 06:25 PM
tulman22
Let us know how it goes and if you can, snap some pics also.
Good luck!!
US Navy "SPOOK" RETIRED
Impact Orange member # 39
tulman22 is offline
rokmen , rokmen slider , sliders , tj
Rokmen Strykers and Rokmen Mercenary Rock Sliders gcally TJ Wrangler Technical Forum 74 12-22-2015 08:32 AM
Installing Winch, Rokmen Bumper, and Rokmen Rocker Guards, how much sag? willhbauto TJ Wrangler Technical Forum 4 03-25-2008 12:02 PM
Rokmen sliders? rb1965 TJ Wrangler Technical Forum 5 01-07-2008 08:01 AM
Installing Warn Rock Sliders Soon : Tips? omnipseudo TJ Wrangler Technical Forum 11 09-10-2004 09:36 PM
any tips for installing my sliders? cptyarderho TJ Wrangler Technical Forum 4 11-26-2002 05:39 PM
