Installing Optima Yellowtop - JeepForum.com
post #1 of 4 Old 09-12-2005, 11:51 PM Thread Starter
WheelinTJ2004
I haven't tried it yet.
Anything I should know....or is it a straight forward install?
Can I use the bar that is currently over the stock battery, or is there anoyher way of securing it?
Thanks
WheelinTJ2004 is offline
post #2 of 4 Old 09-13-2005, 12:03 AM
-RocknRoll-
I put mine in a coule weeks ago, and its pretty straight forward. You shouldn't have any problems with it, and optima yellow top batteries is one of the best on the market if your gonna run a rig with many different options, stereo/rock lights/winch/etc. Good luck!
2002 Sahara
D60/14b
Atlas, 42" Iroks
-RocknRoll- is offline
post #3 of 4 Old 09-13-2005, 12:05 AM
kizer
kizer's Avatar
Straight forward install. Black to - and Red to +
Use the stock bar to secure it and make sure the nut on the battery cable is tight. Dont torque the lift out of it, but make sure its snug.
When/If you install your battery and if your other battery has been removed for a while your TJ might start up and act a bit funny its because your computer has lost power. Start it up and let it run and it will possilby die and start it again. It re-learn everything and run smooth again.
1600+ Write-ups, and more
kizer is offline
post #4 of 4 Old 09-13-2005, 01:13 AM
Hal
Hal's Avatar
Install just like the others said. Oh, don't forget to wipe the yellow top occasionally when you open the hood to keep that bright yellow look.
'02 TJ Sport
Hal is offline
Yellowtop and Redtop combined.... MilitaryJK4455 JK Wrangler Technical Forum 9 01-02-2010 11:27 AM
installing optima renosurfer TJ Wrangler Technical Forum 50 02-04-2007 06:28 PM
Which Optima to run??? zeeman918 YJ Wrangler Technical Forum 16 04-20-2006 10:28 PM
just installed yellowtop optima KY TJ TJ Wrangler Technical Forum 1 12-19-2004 01:31 PM
Optima red top captain_andrew TJ Wrangler Technical Forum 8 02-16-2004 08:19 AM
