installing my first lift...advice ?? - JeepForum.com
post #1 of 9 Old 01-09-2013, 09:50 PM Thread Starter
hooks
Received my zone 4.25 combo kit.weather and help not on the same page as I apparent must install this now (even if its dark,raining,cold,alone and don't know wth I'm doin) attitude. For a man in this situation wld y'all say go at the bl and mml first then the sl? Read a couple threads that these thing went well for some and thought if ima try anything solo I wanna try the easy first. So I'll b waiting on a voice of reason ,till then maybe I'll give it another pb blaster bath
hooks is offline
post #2 of 9 Old 01-09-2013, 09:52 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Do the SL first. It'll give you more room to do the BL.
Plus you'll be much more confident and will be able to knock out the BL in about an hour like I did.
Also, spray your bolts with PB Blaster or the like beforehand.
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #3 of 9 Old 01-09-2013, 10:03 PM
inthefeildjr
I would do the suspension first as well, then the BL. I would try to get a second set of hands for the motor mount lift and I would do it last.
Good luck and PB blaster is your friend.
inthefeildjr is offline
post #4 of 9 Old 01-09-2013, 10:03 PM
rchase559
I did mine the other way. BL then SL. It gave me more room to repair the broken upper rear shock bolts.
X2 on spraying everything down though. Start at least a week in advance if possible.
rchase559 is offline
post #5 of 9 Old 01-09-2013, 11:46 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
I just did the Zone 4.25" a few days before Christmas. Did BL then MML and then SL. I didn't spray w/ PB in advance and didnt have any issues (only owner and no rust). I think the BL added some nice room for the upper shock mounts.
May TJ of the Month 2015
TexasTJ is offline
post #6 of 9 Old 01-10-2013, 09:36 AM Thread Starter
hooks
Thanks yall for ur advice. Did y'all find any helpful videos
hooks is offline
post #7 of 9 Old 01-10-2013, 09:50 AM
mdm
Farm Wheeler
Originally Posted by hooks View Post
...must install this now (even if its dark,raining,cold,alone and don't know wth I'm doin) attitude...
Why? With the weather we're having around here, I wouldn't be doing anything like this unless I could do it in a garage. I wouldn't be doing any work on a vehicle outside unless it was required in order to get it running NOW. The lower your comfort level, the more likely you are to hurt yourself, damage parts, incorrectly install parts, ...
Unless my current suspension was completely shot and I had absolutely no other transportation, I'd be waiting for better weather if I had to do this outside.
I do have not very fond memories working on a '69 VW in the parking lot at -30 degrees because I had to have it to get to work the next morning. Ever seen what those temperatures do to an air cooled engine? Ain't pretty.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #8 of 9 Old 01-10-2013, 10:09 AM
clg82
there are a couple of great videos on youtube for doing the motor mount lift, and body lift....here they are:
http://youtu.be/7epNdiDQ5zM
clg82 is offline
post #9 of 9 Old 01-10-2013, 11:25 AM Thread Starter
hooks
I hear ya, does seem silly when u use logic but just not my style. Was slightly joking but I get something on my brain I won't stop until its done .its like a kid at Christmas screw the meal can't we just open the presents. Luckly in middle TN the weather is about as predictable as hoping that fart will b silent . Ya just never know . Today is in the 60's,
hooks is offline
