installing load leveling air bags on lifted LJ - JeepForum.com
post #1 of 5 Old 01-10-2012, 08:51 AM Thread Starter
ssuper_nova_71
just wondering if I can install AirLift load leveling airbags on a lifted wrangler.
the instructions tell you to take out the bump stops. will the bags be big enough to compensate for the extra 4 inches of lift? anyone know?
ssuper_nova_71 is offline
post #2 of 5 Old 01-10-2012, 09:42 AM
dreed
dreed is offline
post #3 of 5 Old 01-10-2012, 09:47 AM
fordtech
Take the bumpstop out? The bag should just be making contact with the upper and lower surfaces at ride height I believe. So basically, with 4" lift you will need to compensate for that height change by either getting a 4" taller bag, or putting a 4" spacer in there. I don't think you want a gap between the bag and the upper surface it contacts...
Some details- here: http://www.4x4xplor.com/airlift.html and here, Unlimited04 can probably help: http://www.jeepforum.com/forum/f9/un...ml#post9320554
If you don't use those bags, let me know, this mod is on my list....maybe we could work out a deal!!
fuel in my veins, mountains on the brain......
Current-06 Unlimited. Past- 98 XJ, 95 YJ, some Fords.
BUFFALO NY JEEPERS-
Just your friendly neighborhood x-ford technician...
fordtech is offline
post #4 of 5 Old 01-10-2012, 10:14 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
yes, you can run AirLift bags with a lifted wrangler. As the folks above described, I'm doing it right now. You do not remove the bumpstops.
Step 1: properly set your bumpstop length so the shocks aren't bottoming out, the tires aren't rubbing steel & the bumpstop cup is centered over the pad...just like you normally would for any lifted suspension. Good write-up here, and another here.
Step 2: at ride height, measure the distance from the bumpstop cup to the spring pad, and the diameter of the coil.
Step 3: Call up AirLift with those measurements. Ask what bag they have that will fit those dimensions. Write down the PN.
Step 4: Call up an AirLift vendor and buy the PN you learned in Step 3.
Step 5: Take a trip to the junkyard and buy two ZJ front jounce bumpers. Write-up here.
Step 6: Install the bags as shown in the 4x4xplor write up.
Step 7: Hack the jounce bumper down as I show in my build thread, and install it in place of your original. You can modify your original if you don't want to take the trip to the junkyard, but I kept my original in case I want to remove the bags at some point. Write up here.
Step 8: You can plumb the bags and pump them up as described in the 4x4xplor write up. I found they leak air and need reinflating nearly every day. So I installed an air tank and onboard air compressor, setup to inflate the bags to my desired pressure when I start the engine (more here).
See the links the guys posted above for all the info you need
Note: if your jounce bumpers are damaged/missing/rotted you can get replacements from Crown Automotive (PN 52087636AC).
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 5 Old 01-10-2012, 10:44 AM Thread Starter
ssuper_nova_71
Step 8: plumb the bags and pump them up as described in the 4x4xplor write up.
this is what i wanted to see thanks guys!!!
Leveling a Lifted JK??? BackroadN JK Wrangler Technical Forum 27 01-10-2012 11:33 AM
Jk Wrangler Leveling kit or JK 1.5" Performance Leveling? BORRONGO JK Wrangler Technical Forum 5 07-03-2011 01:38 AM
Installing 1.75" leveling kit dgosman JK Wrangler Technical Forum 11 02-20-2011 12:15 PM
Installing my Teraflex leveling kit and disconnect hardware 01Bama JK Wrangler Technical Forum 2 07-02-2010 11:23 AM
TJ load leveling air shocks / air springs wrecked98 TJ Wrangler Technical Forum 23 05-17-2007 01:23 PM
