Installing Lift on my 1997 Jeep Wrangler TJ - JeepForum.com
post #1 of 3 Old 12-28-2011, 11:21 PM Thread Starter
xalexxromerox
Okay, So i just purchased a 3.25" Rough Country lift kit.. The kit includes:
Front: 2.5" progressive rate coil springs, 0.75" poly isolater spacers, sway-bar links, and transfer case drop kit.
Rear: 2.5" progressive rate coil springs, 0.75" poly isolater spacers, sway-bar links, and track bar drop bracket.
Shocks: Includes (4) RCX Performance 2.2 series shocks.
Is there anything else I'm going to need to get or do to my jeep? I am going to be sporting 33/12.5/15 tires as soon as those come in. Any tips are well appreciated. I will also post before, during, and after pics for yall to see the full progress.
xalexxromerox is offline
post #2 of 3 Old 12-29-2011, 09:45 AM
NotURMailman
NotURMailman's Avatar
Looks like they're going to have you re-drill the front track bar hole... you may want to consider getting and adjustable track bar instead.
I would be concerned with the pinion angle with that much lift on stock control arms.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 3 Old 12-29-2011, 09:52 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I ran that lift with 35's on my 03'. I used a MML and ditched the t case drop.I added 4" springs up front to level it out and re-drilled the front track bar hole like mentioned.Use a lock washer on the bolt so it never comes loose and wallows out the hole.
TheBoogieman is offline
lift advice , Rough Country 3.25" , sye kit
Jeep TJ Wrangler 1997 -2004 ,V-6 Conversion Package , Retaining the Stock Jeep 5?? Travisray91 TJ Wrangler Technical Forum 12 10-05-2011 12:50 PM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
1997 Jeep Wrangler 2.5L 4 cyl... JeepMan905 TJ Wrangler Technical Forum 11 05-31-2007 02:24 PM
Jeep Wrangler 1997 problem jappe TJ Wrangler Technical Forum 30 01-02-2006 09:42 PM
1997 Jeep Wrangler Noises Beach Boy TJ Wrangler Technical Forum 8 09-19-2005 09:03 AM
