Installing heated seat pads, need wire help... - JeepForum.com
post #1 of 20 Old 11-23-2008, 08:14 PM Thread Starter
mikeyours
Hey guys and gals, I will be installing my heated pads for my TJ tomorrow and I need some wiring help. Not sure where the aux fuse is and what to use to power these up. I read a couple of old threads about these but couldnt really understand the wiring and couldnt find pics on it. Any help would be great thanks.
06 TJ Inline 6, 6Speed
4in Rough Country Coil Lift,
33x12.5 Pro Comp MT, 15x10 Crager Soft 8s
mikeyours is offline
post #2 of 20 Old 11-23-2008, 08:21 PM
2jhanna
with the amount of current that this things probably pull, i would think your best option would be to have a relay at your under hood box right of the terminal from the battery through a circuit breaker. then run a direct large gauge (12-14) to the seats. you can energize the relay with a smalled switched ( by ignition and off/on) gauge wire.
you made need a seperate circuit for each seat.
jhanna
denton county, tx
2jhanna is online now
post #3 of 20 Old 11-23-2008, 08:43 PM Thread Starter
mikeyours
http://www.sportsimportsltd.com/pecafidutewa.html
This is the kit that I ordered. It says that each one can be ran off a 12v power sorce.
post #4 of 20 Old 11-23-2008, 08:53 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Mine just plugs into the cig lighter and it vibrates! Do these install under the seat fabric? Why, just get some that sit on top of the seat! Far easier install and you can remove whenever?
GOLENJEEPTJ is offline
post #5 of 20 Old 11-23-2008, 08:55 PM
2jhanna
12volt was assumed but the current draw was in question. looking at specs, each seat draws 5amp on high. i would still run 2 seperate circuits (10amp each). you can do this from the fuse box behind the glove box.
get 2 "bussman add-a-circuit"s from the auto parts store, about $6 each. also get some 10amp fuses.
see link below
http://www.bussmann.com/images/3c2dc...86ccd13aad.JPG
these will enable you to have 2 new circuits. one for each seat. then follow the install instructions for the seat heaters
edit: if there is only one switch for both seats, then just one circuit would be needed. that way i guess both seats are on even if only one person is present.
jhanna
denton county, tx
post #6 of 20 Old 11-23-2008, 08:59 PM Thread Starter
mikeyours
2jhanna, awesome just the answer I was looking for. What am I looking for exactly behind the fuse box?
And yes they do go under the seat, I just like the look of a cleaner install and if I got the pad it would just be one more thing inside.
post #7 of 20 Old 11-23-2008, 09:26 PM
2jhanna
if you just need 1 fuse space/circuit (meaning both seat heaters are controled by one switch). buy 1 of the add-a-circuits (autozone has them in my area). in the fuse box behind the glove box, unplug the fuse for your cigarette lighter (it is # 19 in my `02, check your manual). plug that fuse into your new add-a-circuit, the position NOT next to the red wire. plug a new 10 amp fuse in the position next to the red wire. now plug the add-a-circuit in slot #19 (where you removed the fuse from). MAKE SURE THE RED WIRE IS POINTING TOWARD THE STEERING WHELL SIDE.
if you have a 12v test light, you can check the inside blue terminal at this point, should be on when ignition is on.
the red wire is where you will crimp your seat power red 12v wire. the ground wire you can hook up to a good ground somewhere.
where do you plan to mount the switch ??
jhanna
denton county, tx
post #8 of 20 Old 11-23-2008, 09:54 PM Thread Starter
mikeyours
It does have two switches for each seat, but I think people hook them up together and say its fine that way.
I think im going to put them on my dash, where normally the passenger airbag turn off is. I have an X so I dont have that on my dash just blank. or somewhere in the center
post #9 of 20 Old 11-23-2008, 10:37 PM
2jhanna
or mount your switches on the center console, maybe somewhere below the armrest, maybe above where the parking brake handle slot is.
run the wires from the fuse box down the middle, under the console, mount the switches next to the brake handle, then run the wires under each seat.
just a thought,
jhanna
denton county, tx
post #10 of 20 Old 11-24-2008, 02:23 AM
jeep2008
i've ordered these also!!!pretty please take photos and do make a write up if you can,beginning from the upholstery of the seats, the wiring etc!!
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #11 of 20 Old 11-24-2008, 03:03 AM
jeep2008
check also these two writeups ,they may come in handy until you write yours :http://www.customtacos.com/forum/sho...d.php?t=104177 http://www.jk-forum.com/showthread.php?t=39723
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #12 of 20 Old 11-24-2008, 06:24 AM
Jonny Jeep
Jonny Jeep's Avatar
Here's a write up for TJ seats...
http://ewylie.com/jeep/seatheat.htm
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #13 of 20 Old 11-24-2008, 03:45 PM
jeep2008
great writeup !here are a couple of pics i found from another tj that has them
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #14 of 20 Old 11-24-2008, 07:46 PM
XXRider
I wouldn't run that much power throw those little switches. 5amp isn't too bad but 10 is getting questionable. Besides why draw a extra 5 amps when someone isn't using that seat.
XXRider is offline
post #15 of 20 Old 11-24-2008, 08:06 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
here's mine.
http://www.jeepforum.com/forum/f9/tj-seat-heaters-502026/
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
Heated Seat Kit? 2003X TJ Wrangler Technical Forum 26 02-04-2010 08:00 PM
Installing new front brake pads on 05 TJ gmcd TJ Wrangler Technical Forum 4 07-14-2009 06:38 PM
JK Heated Seat Install BC Jeep JK Wrangler Technical Forum 10 02-14-2009 09:43 AM
Bleed Brakes When Installing New Pads...? thejafe TJ Wrangler Technical Forum 12 09-17-2006 01:47 PM
Heated Seat Pads... sandman'sjeep YJ Wrangler Technical Forum 9 12-21-2005 09:44 PM
