Installing gears and need help picking traction adders for a DD TJ
| Introducing MONSTALINER UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
| View Poll Results: What Traction adding device combo would you choose? | |||
| Detroit Truetrac L/S front and rear |
11 | 45.83% |
| Powertrax No-Slip rear and Truetrac front |
3 | 12.50% |
| Auburn ECTED Rear and open front for now aussie later on |
6 | 25.00% |
| Auburn ECTED Front and stock Trac-Loc rear |
4 | 16.67% |
| Voters: 24. You may not vote on this poll | |||
#1 | |
I am going to be installing 4.56's in about 3 weeks front and rear in my 2001TJ D30/D44 and am trying to stay somewhat on a budget. I am trying to decide if I should go whith one of four set-ups. It is my DD and I am going with 33" tires no bigger on a short arm lift and dont plan on doing anything crazy but want the benifits of greater traction to help with the Colorado trails.
1. True-trac's front and rear 2. Powertrax no-slip rear / Truetrac front 3. Auburn ECTED Rear / open front for now with an Aussie later 4. Auburn ECTED Front and stock Tracloc rear 5. SOME OTHER RESONABLY PRICED SET UP THAT IS SUGGESTED
#3 |
I would love to but dont think I can afford it at the moment. I am already having to begg the ol lady as it is
#4 |
I would do the Ected in the front and leave the rear for now. That way you have a good selectable locker in the front, a lsd in the rear and then later you can add a locker to the rear. Personally I put an Aussie in the front and a Trutrac in the rear but I have a 35.
2004 Tj X, 2.5 Skyjacker rear, OME ZJ front, 285/75 16 A/T's on moabs, Bedlined stuff, some offroad Lights, Warn 8274 w/ Warn plate, Aussie front, Truetrack rear, PSC trail corners, Pro-comp adjustable front trackbar, 1 1/8" skateboard wheel bl, Teraflex bmml |
#5 |
i don΄t like teh ected. a freind had many problems with it.
2 truetracs are a good chioce for a daily driver. if you have the money go with 2 selectable ARB lockers. i have 2 ARBs, a friend has 2 truetracs. with deactivated ARBs in my jeep he can do much more than i do. but with only the activated rear ARB my TJ is better in deep mud than his jeep with the truetracs. forgot to say that we both habve nearly the same setups and the same tires.
2.5" OME & 2" Spacer & LT Shocks 2" BL 1" MML JKS Discos JKS Rear Links OME Steering Stabilizer 35x12.5x15 Cooper STT @ 8.5x15 ARB Airlockers ARB Diff Covers 4.56 Gears SS Brake Lines Warn Skids Genright Rock Slider Smittybilt Rock Crawler Rear Bumper Safari Snorkel OBA 12.000 lbs Winch Synthetic Winch Line 4x 130W Hellas 4x 200W Hellas @ Lightbar E-Fan Jeep TJ Runicon Pics www.timbercrawler.de |
#6 |
Feeding the money pit
I sent with TrueTrac up front and an ARB in back, love the combination. If you weren't where it snows I'd say do a autolocker in back and a TrueTrac up front to save a buck, but after trying driving with the ARB locked this winter I'd say no way.
Dave Shannon Durango, CO '01 TJ Sahara '98 XJ Sport '00 XJ Wife's ride Gone but not forgotten '56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr |
#7 |
If i can get a good enough deal on the parts I may be ablr to do an Auburn ECTED Rear and Truetrac front I supose I hadnt really thought about that combo. But the ARB is out because of price for the locker and the compressor I could just about get the ECTED, Truetrac and Diff protection
#8 |
I run a Aussie up front and a Truetrac rear. I went that way since I tend to lift a tire in front a lot more than the rear offroad. The Truetrac out back also works well being my daily driver.
#9 |
lunch box up front and Detroit in the rear? thats what i would do
stuff |
#10 |
Do it right or not at all
![]() Join Date: Jan 2003
I hope you realize that your TJ can have a front automatic locker without having any issues in 2wd. It looks like you may believe your TJ can't run a front locker without steering problems, which is not the case with a TJ.
What type of wheeling do you do? Do you require 4x4 on paved roads in the winter when (if) your local roads are iced up or covered with snow? When you go wheeling, is the trail uneven enough that you lift a tire up off the ground? Would you like front and rear lockers but are afraid to have one in the front for steering issues you may have read about?
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#11 | |
#12 |
If you dont need top worry about driving on the road in 4wd, lock the front and rear with an Aussie for 500 bucks. Thats what I would have done if I had a D44. The only way I even know the Aussie is in the front in 2wd is I hear it clicking when I turn.
#13 |
It looks as though no one like's to vote in the poll's or they just dont have an opinion.
#14 |
if funds are an issue, why not just do it right on one of the axles vs. going with something cheaper for both axles now. a selectable in the front or rear by ARB or OX. Still waiting on more research for the ected. lunchbox in the front is pretty popular in alaska for those budget minded folks, now do they drive in 4hi on the street, i don't know, but many are pushing aussie up here.
#15 |
aussie up front and an ECTED in the rear. i have both and have not had any problems and would do it again
Photographer at heart Have questions about something photography related? Click here!Like Coheed and Cambria? Join the club! My Jeep Build My Photography (New as of Jan. 25th) 1982 Motorcycle Build |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
