Installing front brake rotors and pads myself ? - JeepForum.com
post #1 of 3 Old 07-23-2010, 01:14 PM Thread Starter
LMG23
I just received a set of centric premium rotors and ebc green pads. How difficult is it to change out the old rotors and pads myself ? How much would a mechanic usually charge for such a job ? I am mechanically inclined, I swapped out a rear bent drive shaft, installed my body lift etc. Any help would be greatly appreciated.
LMG23 is offline
post #2 of 3 Old 07-23-2010, 01:21 PM
MATT99TJ
Should be easy. I recently changed out the rotors and pads on my wifes exploder. Using the Chiltons manual and some uhm.. help, if you could call it that, from my wife we had the front done in rather quickly.
MATT99TJ is offline
post #3 of 3 Old 07-23-2010, 01:22 PM
NorCalCon
Super easy!
NorCalCon is offline
brakes , rotor , pads , ebc , install , diy , advice , tj , wrangler
Installing new front brake pads on 05 TJ gmcd TJ Wrangler Technical Forum 4 07-14-2009 05:38 PM
Recommended Brake Rotors & Pads? cvd TJ Wrangler Technical Forum 35 08-19-2008 10:07 PM
Upgrading front brake pads and rotors? 05moabTJ TJ Wrangler Technical Forum 16 06-08-2008 09:26 PM
Need help with replacement brake pads and rotors bshwckr TJ Wrangler Technical Forum 10 07-26-2006 12:45 AM
Brake Pads And Rotors WR4NGLER TJ Wrangler Technical Forum 50 07-23-2004 05:31 PM
