Installing Detroit locker in Dana 35 - JeepForum.com
post #1 of 13 Old 12-01-2009, 01:01 AM Thread Starter
herculz
2010 JK Wrangler
Question, before i get hammered on doing this, is the process to install a detroit locker in a d35 for tj difficult or is it as simple as installing an aussie locker. i have a chance to get a locker with shafts (incase i break one) for about the same price i paid for my aussie locker.
herculz is offline
post #2 of 13 Old 12-01-2009, 01:04 AM
bmxrules39
first- don't do it
second- it's about 400 times harder than an aussie. You will have to re-gear, which takes many special tools and about 8hrs.
§wHitt§
bmxrules39 is offline
post #3 of 13 Old 12-01-2009, 01:19 AM Thread Starter
herculz
2010 JK Wrangler
damn i guess i will stick to plan A on the arb for my front in the mean time.
herculz is offline
post #4 of 13 Old 12-01-2009, 03:01 AM
Jeepster83
or you can take the deal and sell it for a slight profit to help pay for something else...
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #5 of 13 Old 12-01-2009, 05:35 AM
never monday
is the Detroit 27 or 30 spline?
never monday is offline
post #6 of 13 Old 12-01-2009, 07:37 AM
champelite210
I don't think it would be hard. All you need to do is take out your open diff. Take your open diff and detroit to a local shop with a press. Take the bearings and shim packs off the open diff and put them on the detroit and throw it back in. If I had to choose over a detroit or aussie in the rear I'd definately want the detroit.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #7 of 13 Old 12-01-2009, 10:35 AM Thread Starter
herculz
2010 JK Wrangler
27 spline, its used, but i think i will do it right and wait to save for my arb up front and then look for an 8.8 axle from a explorer right? what year should it be and how can i tell since i've never owned an exploder?
herculz is offline
post #8 of 13 Old 12-01-2009, 10:37 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep, don't install a locker into a stock Dana 35c axle, it's not strong enough for that.
Getting
Jerry Bransford is offline
post #9 of 13 Old 12-01-2009, 10:42 AM
Ross
I believe with ARBs you will need different carriers for different gears. I would handle you axles and gearing before the locker. If you have stock gears the will probably be 3.73 or less. If you get an ARB now and want to regear latter the ARB you get now may be useless for you later. At least check into this before you start spending $$.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #10 of 13 Old 12-01-2009, 12:12 PM
lostsheep
Granted I am no expert, but I doubt two different carriers would require the same shimming. Isn't that why there are shims, because no two are the same and you are stacking tolerances?
lostsheep is offline
post #11 of 13 Old 12-01-2009, 12:19 PM
Stop being a
You are correct.
There may be two out there that are idedenical, but what are the odds you happen to have them.
Stop being a is offline
post #12 of 13 Old 12-01-2009, 12:49 PM
champelite210
Believe it or not. I've done it about 4 times now. If all your doing is moving the ring gear from one carrier to the other you can use the old shim pack and be almost perfect. Don't get me wrong you should check backlash to be sure. I've never had to change one yet. I've switched my front from open to detroit tru trac and now to detroit locker all using the same shim packs. And the rear went from open to e locker using the same shims.
The reason for shims is because of different gear thicknesses and differences in housings. Most carriers are really close to the same specs.
post #13 of 13 Old 12-01-2009, 08:42 PM
chutta
Wouldn't it be easier carrying and replacing shafts(stronger carrier with the det) than dealing with spiders and cracked carriers?
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
Installing Detroit in Dana 30..... Tuffjeeper TJ Wrangler Technical Forum 35 02-09-2010 11:56 AM
Detroit Locker Dana 44 Tuffjeeper TJ Wrangler Technical Forum 1 05-21-2009 09:27 PM
installing detroit locker rubiwannabe TJ Wrangler Technical Forum 2 09-13-2008 06:05 PM
Installing a Detroit E-Z locker. how hard? kowalsy YJ Wrangler Technical Forum 1 02-02-2005 09:47 AM
