Installing control arms for first time, good write ups? - JeepForum.com
post #1 of 15 Old 10-15-2009, 12:54 PM Thread Starter
$lick
I am going to have my little brother with me (who drives the jeep more than I do) help install these fixed lower control arms that I recently purchased. I am looking for a good write up so he can visualize what needs to happen and use it as a good reference, I know there is not much to it, but a nice write up that maybe stu or 4x4xplor has would be great, at work and those sites are firewalled.
Thanks a ton guys.
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline
post #2 of 15 Old 10-15-2009, 12:58 PM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
I just removed two bolts each and replaced two bolts each then torqued them down and was done.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 15 Old 10-15-2009, 01:10 PM Thread Starter
$lick
torque specs?
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
JKS Disco's
Axle specs:
Riding on:
33x12.50 BFG A/T
$lick is offline
post #4 of 15 Old 10-15-2009, 01:16 PM
jdhallissey
Good and tight. I think they are suppose to be 90 ftlbs. Do one side at a time. You don't even have to jack it up if it is lifted.
jdhallissey is offline
post #5 of 15 Old 10-15-2009, 01:17 PM
IOUnlimited
Its a full lift install but you can just refer to the control arm portion.
Round #2 - Main Page
IOUnlimited is offline
post #6 of 15 Old 10-15-2009, 03:38 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
just remove & install them one at a time. adjust to length needed if they're adjustable. i didn't even jack my jeep off the ground when unbolting the control arms individually.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 15 Old 10-15-2009, 04:21 PM
jeepy01
i think that torque specs are 130 at the frame and 80 at the axle i wud double check those numbers tho
jeepy01 is offline
post #8 of 15 Old 10-15-2009, 04:50 PM
UnsanePyro
If you are having a little bit of a problem getting them to line back up, try a jack under the axle, it helped line mine back up
UnsanePyro is offline
post #9 of 15 Old 10-15-2009, 05:56 PM
jeepy01
i had this problem, put a jack right under the pinion so it tilts the axle.
jeepy01 is offline
post #10 of 15 Old 10-15-2009, 06:30 PM
Cjensenr
I believe they are more likely to be approx. 45 -75 ft/lb. I can't recollect right at the moment....CRS!
C.
Cjensenr is offline
post #11 of 15 Old 10-15-2009, 07:13 PM
Roye77
2011 JK Wrangler
Not sure what kinda ends your control arms have poly, rubber or JJ but its a good idea to have it sitting on the ground before you completly torque the bolts or your going to rip your bushings.
"All men are created equal, then a few become firemen." ~Author Unknown
"Volunteer firemen do it for free!" ~Author Unknown
Roye77 is offline
post #12 of 15 Old 10-15-2009, 11:38 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Torque specs below for you.
http://www.jeepforum.com/forum/f9/tj...-specs-474605/
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #13 of 15 Old 09-17-2012, 11:05 AM
jstman
Realizing this thread is old, and it's probably a simple job, I have a few questions:
This sounds like I can swap the control arms with the vehicle sitting on level ground, tires on, etc. Is that correct?
Are there any precautions I need to make before removing the control arms? (One at a time and replacing it before doing the opposite side)
Any concerns about the axle rotating, thereby causing the body to drop and pin me under the Jeep?
I realize this is probably a simple job, and it looks simple. I put the lift on myself, so I'm not an idiot,but want to make sure I'm not missing anything.
Thanks in advance.
jstman is offline
post #14 of 15 Old 09-17-2012, 11:11 AM
Zombi
Correct but removing the tire makes it much easier to get in/around.
Just make sure the arms you're putting in match in length, side to side. The pinion may rotate a bit so before removing any arms just take a jack and put some slight pressure on the housing directly underneath the pinion to prevent it from rotating.
The body won't drop on you as long as you have springs installed. Just be smart and don't put yourself under the lowest point of the axle just in case, weird stuff happens.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #15 of 15 Old 09-17-2012, 11:24 AM
jstman
Thanks Zombi
jstman is offline
Any advice on installing control arms Roye77 TJ Wrangler Technical Forum 15 09-18-2009 02:26 PM
installing control arms question mikesbeachhut TJ Wrangler Technical Forum 10 07-21-2009 08:42 PM
Installing Upper control arms 05RedRME TJ Wrangler Technical Forum 4 07-14-2009 10:28 PM
Help installing new lower control arms......PLEASE HemiHead426 TJ Wrangler Technical Forum 14 12-23-2007 04:22 AM
