Installing Aussie - JeepForum.com
post #1 of 13 Old 02-25-2007, 03:53 PM Thread Starter
tmwoodall
Installing Aussie
I was going to go to a shop and have them do it. But now I am so close to going home now that I am thinking I might try this out on my own. How hard is it? A guy in my club said it took him several hours for the lack of tools and first time trying something like that. I have the tools and the space. How hard is it actually 4x4explor makes it look like a two hour job which I know it is not....
tmwoodall is offline
post #2 of 13 Old 02-25-2007, 03:56 PM
SecondTJ
SecondTJ's Avatar
since there is no adjustments needed with it (backlash, pinion preload, etc) it is a fairly straight forward install with the right tools
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 13 Old 02-25-2007, 05:05 PM Thread Starter
tmwoodall
Ok Thanks I think I will give it a shot and buy myself a muffler instead of having it installed.
post #4 of 13 Old 02-25-2007, 05:11 PM
Lostj
Lostj's Avatar
I put one in my d30 and it was very easy.
The only things that gave me trouble was:
trying to "pop" the carrier out of the axle
and
trying to get the carrier to stay put on the tiny vice that I was using when i was taking on/off the ring gear bolts.
this is what worked for me for getting the carrier out:
http://www.stu-offroad.com/axle/d30seals/seal-5.jpg
(http://www.stu-offroad.com/axle/d30seals/seal-1.htm)
and here are some write-ups:
http://www.offroadlockers.com/manual...d0f/4e25/.html
http://www.jeepforum.com/forum/f37/how-install-lunchbox-locker-ex-locker-aussie-locker-etc-your-d30-axle-115029/
http://mrpistol.tripod.com/id58.html
http://home.off-road.com/~nobucks/locker.html
I printed this one out:
http://www.4x4xplor.com/aussielocker.html
00'TJ
74'CJ5 For Sale
Lostj is offline
post #5 of 13 Old 02-25-2007, 05:59 PM
Chris_
that was the only thing that gave me a headache. my vice is bolted to a pretty big workbench, and it was still a pain. i ended up getting a socket wrench on each one, then hammering at it with a mallet. if i just tried to push it, my bench would start moving.
other than that, mine just took about 3 hours by myself.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #6 of 13 Old 02-25-2007, 09:50 PM Thread Starter
tmwoodall
awesome guys thanks. I am going to get a muffler instead of having it installed
post #7 of 13 Old 02-25-2007, 10:28 PM
SilverJ
SilverJ's Avatar
I removed the ring gear with an impact and never used a vice, even though I do have one! Anb, with the proper tools it was a two hour job. Though the previous weekend I Miller locked the rear, and that was a little more in depth. Good luck!! You will laugh at how easy it was once you are finished. Tell us all how it went!
SilverJ is offline
post #8 of 13 Old 02-25-2007, 10:31 PM
Tacoma750
Sometimes the aussie requiers grinding to the housing to make it fit....Some do some dont.Mine did
Tacoma750 is offline
post #9 of 13 Old 02-25-2007, 10:47 PM
Lostj
Lostj's Avatar
what axle?
00'TJ
74'CJ5 For Sale
Lostj is offline
post #10 of 13 Old 02-25-2007, 11:02 PM
JamboreeTJ
1946 CJ2A
You need a long punch to remove the cross shaft. NAPA should have one.
You need a large enough vise to properly torque the ring gear after putting the Aussie in.
It is a good mod to do yourself. You'll learn a lot.
JamboreeTJ is offline
post #11 of 13 Old 02-25-2007, 11:31 PM
Tacoma750
Dana30 is the axle that SOMETIMES needs the housing ground
post #12 of 13 Old 02-25-2007, 11:36 PM
Lostj
Lostj's Avatar
when I did mine I thought I was going to have to do that, but I changed the order that I was putting the gears in and they went in smoothly and I had no problems
all jeep are different
00'TJ
74'CJ5 For Sale
Lostj is offline
post #13 of 13 Old 02-26-2007, 12:57 PM
PeteC
I can't even think of a spot where grinding might even have been remotely needed. But I guess that's just me.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
installing an aussie... got a few questions JIBTEXHNKA YJ Wrangler Technical Forum 8 12-08-2009 05:28 PM
installing aussie, tips on removing axle hub? alecmcmahon TJ Wrangler Technical Forum 10 01-11-2009 06:55 PM
installing aussie in 8.8 problem LeeGro TJ Wrangler Technical Forum 3 03-27-2008 09:32 AM
Installing Aussie Lockers Kalesinajeep YJ Wrangler Technical Forum 25 03-20-2008 10:02 AM
installing aussie locker d30 help KeepRockin024 YJ Wrangler Technical Forum 5 07-30-2007 04:32 PM
