Installing 3" hybrid lift - Page 7 - JeepForum.com
post #91 of 97 Old 04-24-2010, 01:28 PM
FloridaFD
05RubiLJ,
I know you were shooting for a one time 3" lift using the AEV Coils. What is the bare minimum that is needed to run the AEV 3" coils, maybe Mudb can help here? Are UCA and LCA absolutly needed to run your set up?
Thanks for your help.
FloridaFD is offline
post #92 of 97 Old 04-24-2010, 02:29 PM Thread Starter
05RubiLJ
2014 WK
Originally Posted by FloridaFD View Post
05RubiLJ,
With your LJ, you might be able to go with shocks/springs, rear trackbar relocator, rear and front sway bar extentions/disconnects and bump stops.
If you find you have vibes, those could be handled with BL/MML or with LCAs.
05RubiLJ is offline
post #93 of 97 Old 04-24-2010, 10:50 PM
mudb8
want it rite or rite now?
mudb8's Avatar
05RubiLJ,
3" coils are a bit much without track bar relocation and you would likely need to drop the belly pan a little to fix a vibration..
You'll get away with just coils and shocks , but be prepared for some vibration and off centered axles.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #94 of 97 Old 04-24-2010, 11:04 PM
Imped
Imped's Avatar
With the longer drive shaft of the LJ, it's unlikely that you'll get vibes with 3" of lift. The axles will be pretty off-center, though.
OlllllllO
IndyORV
Imped is offline
post #95 of 97 Old 04-24-2010, 11:25 PM
mudb8
mudb8's Avatar
I wouldn't have mentioned it If I hadn't had to fix a couple.....
I had to put a CV shaft on cb3's rubi with OME 2.5" coils to avoid dropping the skid.
mudb8 is offline
post #96 of 97 Old 07-15-2010, 06:45 AM Thread Starter
05RubiLJ
2014 WK
Update
Originally Posted by lumpster View Post
very nice, i hope it performs as well as it should off road and on road.
Well, I just got back from driving ~3400 miles from Texas to Arizona and back. Went all over the state from Tuscon to Page (on the Utah border). I got the chance to do some wheeling in Sedona - what a great place to drive! For those who know the area, I ran Cliffhanger, Soldiers Pass, Broken Arrow and Powerline. I have also added UCF t-case/engine skids and a LOPRO tranny mount.
The LOPRO with the rubber isolators give quite a bit of vibe at idle. I told my wife that it is the massaging seat upgrade She doesn't really like it but it doesn't bother me that much. I also have installed a Tuff Designs bumper/tire carrier/trail rack. I really struggled with the decision here due to some of the bad reviews on it but the jerry can placement and extra storage options was the best for me. I have two Scepter OD green MFC that are mounted in the swingout as well.
We had the Jeep packed full of stuff for the 10 day trip to AZ and while I didn't take a measurement of height, but there was minimal drop with 2 full MFCs, 5 Gal water, and luggage for 3 people, there was no space in the rear seat for another person and the back of the LJ was packed to the roof. The drive was pretty good but fully loaded, the 4.0L has a hard time keeping 75-85 through the hills in west Texas, NM and AZ. My wife told me I need a bigger engine Not sure what I want yet but it will likely be a stroker kit rather than deal with all the changes required for a HEMI/Chevy V8 option.
The suspension performed very well on the trails in Sedona. I only barely hit the corner of the rear bumper once and that is because I goosed the throttle on the way through a crevice on Broken Arrow. On the way to powerline, there is a long gravel washboard road that was absorbed very well by the progressive springs. At full stuff in the back, I noticed that I was about .25" from the ridge in the back of the wheel well. The 10.5" wheels stuff very nicely into the front corners as well. I climbed most everything without the rear locker engaged - there was a time on powerline that I needed the rear locker. The trails I ran were between 1-3.5+ for AZ ratings (2-7+ in the rest of the country) and I ran the tires at 22 psi. I am extremely pleased with the setup. The technical driving required to navigate a 7 rated trail is more than enough for me at this point. I had a bit of a "pucker moment" on powerline when my rear wheels didn't catch the step right and skipped me near the cliffside edge. Once the locker pump engaged the rear locker, I was able to walk up the step with minimal issues. I only had one nub on one of the rear tires that got ripped off during the trail runs.
I didn't take many pictures since I was having fun just running the trails but here is a pic of my son and I coming back down the slick rock on Soldier's Pass near the Devil's Kitchen
05RubiLJ is offline
post #97 of 97 Old 07-17-2010, 01:57 AM
mudb8
mudb8's Avatar
mudb8 is offline
currie , hybrid lift , nth , nth degree , ome
Installing 1" BL and 2" suspension lift-will I need an MML or TC drop? Marauder_Pilot TJ Wrangler Technical Forum 5 09-16-2008 12:22 PM
installing 1" body lift and 1" motor lift is there anything i should know about them? crawlr TJ Wrangler Technical Forum 16 08-21-2008 05:42 PM
Installing 3/4" spacer on 2" lift Libtekguy TJ Wrangler Technical Forum 1 05-09-2007 11:44 AM
Installing 2" boost, 1" body lift Poseidon17 TJ Wrangler Technical Forum 3 02-04-2003 05:31 PM
Is there any disadvantage to installing a 1" body lift and 1"M.O.R.E motor mount lift DLoweinc TJ Wrangler Technical Forum 10 01-17-2003 05:37 PM
