#1 | |
Installed seat heaters...
Very nice. Here's a link to the Ebay ad:
About $150. I mounted the switches just behind the gear selector and just in front of the e-brake handle. The install was relatively easy. The heaters only require a ground and a switched ignition source. Everything else is plug and play. Certainly helps on cold mornings. The seats get warm before the heater does.
2001 TJ 4.0L with 3sp Auto, OME HD "Ultimate" Kit, 33" Kumhos on Pro Comp 1069's, Bestop Tire Carrier, Nate's 4x4 Rear Bumper, Stubby Front Bumper, Power Windows and Locks, Power Tailgate Lock and Dome Light Switch, Seat Heaters |
#2 |
i'll be donig this for next year
#3 |
Do you have them under seat covers? Or did you remove the factory seat covering to install?
Got pics of the switches? Interesting and neat mod....good job!
05 [B]Black[/B] TJ Rubicon 2" Spring lift, Hella 500's on the windshield, SRC front bumper, SRC rear bumper w/ tire carrier, SRC rocker guards/steps, Mile Marker PE8000 winch |
#4 |
Pictures? Writeup? Anything else to help me do it myself.
2006 Rubicon Unlimited Khaki: AUTO, 4:11 D44/D44, REBB /w Mono tubes, Rancho front stabilizer, 31 x 9.5 LT245/75R16 MTRs, Stock 16in Moab Wheels, Olympic Reverse-A-Bars,KC Daylighters on windshield brackets, Garmin Nuvi GPS, Pioneer Sound, 3A fire extinguisher, Line-X interior... www.stevensinger.org <-- Photography website Hello, my name is Steve and I am a Jeepaholic. LJ Owners Member 155 Rubicon Owners Member 123 New Jersey Jeepers Member 44 |
#5 |
I did mine in early January. It is great. The real question is how I lived without one for ten years. I put it under the seat cover above the seat upholstery. In summer I always have Wet Okole's on, and I bought sheepskins for winter. The heat transfers well through both.
Jarhead Jeep Club O|||||||O 97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders. My Build Thread http://www.jeepforum.com/forum/f22/my-jeep-history-1997-present-1304114/#post12717920 |
#6 |
Yeah pics would be nice
Black 2010 Sport JK Black 2003 Sport TJ Gone! |
#7 |
Mo****rless
How long until you feel warm?
#8 |
Cant edit my user title
Andy, KD8EIA | USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers | "Don't take life too seriously, You'll never make it out alive." "A government big enough to give you everything you want is a government big enough to take from you everything you have" - Gerald R. Ford in an address to a joint session of Congress on August 12, 1974 |
#9 |
Low current draw too, nice.
don't need them here though ![]() ![]()
God Rules! |
#10 |
Interested in how you wired to power.
Do you have individual switches for the left and right seat? Or is it one switch for both seats? |
#11 |
I knew I shouldn't have posted without pics first.
To answer a few questions: 1. I put them under the factory seat covers. It's not too hard to do, but you do have to take the seats out and separate the back from the bottom. Slipping the heaters under the covers is pretty simple. 2. Each seat has an individual switch that has a low and high setting. It also had an indicator light that is red when on high and green when on low. 3. It takes about 2 or 3 minutes to start feeling the heat. It's kind of strange...I tested the heaters before I put them in the seats and they don't actually get that hot to the touch. Even when they're in the seats, the seat fabric doesn't get that warm. But when you're sitting on them, the heat really builds up. 4. I tapped the aux. (ignition) power fuse in the glove box fusebox. I think it's the 3rd from the top on the left side. There's also a constant power fuse right above that one if you need it for any other electronics. 5. Here's a link to the write-up I used to get started. This person was installing a different brand of seat heater, but the basic process is about the same. Install Link 6. I can take some pics later on this week of the installed switches and upload them.
#12 |
I've done an install of these with a katzkin leather kit in a car before. It was really easy and anyone with even a little bit of mechanical knowledge can do this mod. You don't typically see heaters without leather. I wonder if there is any kind of fire hazard with cloth covers.
2005 Rubicon Unlimited Sahara Edition 605/1000 2001 WJ Limited - Sold www.rubiconsahara.com |
#13 | |
#14 |
Very cool mod....the pic of the switches on that install link is great. It looks OEM!
Def doing this for next winter
Solar Yellow '04 TJ Sport, RE 3.5" Standard Kit w/ GEN 2 Discos, 33x12.5R15 Cooper Discoverer STT's on Black Crager D Windows, OME Shocks and Stabilizer, LOD Xtreme Duty Rear, Jeeperman Front w/ Pre-Runner Bar, Viair Constant Duty OBA - Front & Rear Quick Air Discos, Firetruck Air Horn, Galls Siren w/ PA, CARR Rotabar w/ KC Long Range Lights & KC Driving Lights, KC Fogs, Superwinch 9000lb, Viking Synthetic Line, Optima Yellow Top |
#15 |
I'm biting
RE 3.5 Super Flex, Old Man Emu Long Travel Shocks and Steering Stabalizer, RE Hack & Tap SYE, AA CV Drive Shaft, ARB Compressor, ARB Front and Rear Lockers, 35x12.5x15 Cooper STTs, Custom Fabbed Bumpers, ORFAB rear tire carrier/ gascan holder, Superior 4.88s, and Heated Seats |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
