Installed mechanical oil pressure gauge, how can i disable the check gauges light - JeepForum.com
post #1 of 10 Old 03-20-2009, 07:48 PM Thread Starter
dolannd
HI guys, i've just installed a mechanical oil pressure gauge since the original one was acting up and now the check gauges light stays on at all times as i left the original sending unit disconnected, Does anyone know if the check gauges light would alert other issues than the oil pressure?
If yes, what can i do to the old oil pressure sending unit connector to disengage the light.
Or more speciffic what can i do to not have the light on but still have it functional in case it does alert on other issues than the oil pressure?
Any help is appreciated!
dolannd is offline
post #2 of 10 Old 03-20-2009, 08:23 PM
wtroger
If the original was an electric gauge then yo should be able to put a resistor across the connectors and turn off the check gauge light. The only thing I can't tell you is what size resistor the shop manual will not give me the value range of the pressure sensor it just says it is a variable resistor diaphram type sensor. feeding info to the PCM. I am not up on the Jeep system well enough to know maybe some else will chime in on the value
wtroger is offline
post #3 of 10 Old 03-20-2009, 08:28 PM
XXRider
Edit ... Looks like I was beat to the punch....
I don't have a answer to how but I'm sure you can feed the computer a level that is "good". That would have the computer keep working normally without a code.
My guess is you will need to a resistor that is in the same range the computer reads as normal.
A must-read for new TJ owners/forum members
XXRider is offline
post #4 of 10 Old 03-20-2009, 09:49 PM
ODA 074
I would replace the sensor and find a T coupler at a hardware store and attach both sending units. That is what I did for my 97 - both gauges will work. From my experience, my aftermarket gauge is much more accurate - the factory gauge hovers from 20 to 40 and my computer stays happy. The only gauge you will not be able to run in tandem is your gas gauge (from my experience).
ODA 074 is offline
post #5 of 10 Old 03-20-2009, 09:51 PM
azcoyote
azcoyote's Avatar
Hmm.. Not sure this will work but... Can a ohm meter be used to test the old gauge to get the resistance?
Just a thought but I could be completely wrong? Anyone know?
JEEPLESS... :(
azcoyote is offline
post #6 of 10 Old 03-20-2009, 10:21 PM
ODA 074
Sorry man - just reread your post, I failed to see that you are running a mechanical gauge. I'm running all electrical gauges; I personally don't have any experience with mechanical units.
ODA 074 is offline
post #7 of 10 Old 03-20-2009, 10:38 PM
XXRider
Maybe, but you may have to get the sensor to a normal oil pressure to get the right reading.
XXRider is offline
post #8 of 10 Old 03-21-2009, 05:58 PM Thread Starter
dolannd
Thanks for the replies, i might go with the T fitting, seems like the easiest solution.
dolannd is offline
post #9 of 10 Old 03-22-2009, 08:58 AM
Tim
Tim's Avatar
t-fitting is the way to go, been running like that for many years. the tj likes its stock sensors. i would find a way to keep them hooked up whenever a mechanical gauge is put into play.
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88
There are no shortcuts to any place worth going
91 XJ 4.7
Tim is offline
post #10 of 10 Old 07-15-2012, 10:47 AM
rcs8
Mechanical Oil Pressure Gauge
What size T-fitting is required?
You're unique, just like everyone else.
rcs8 is offline
Check gauges light/ Low oil pressure esad_b TJ Wrangler Technical Forum 18 10-19-2016 03:04 AM
check gauges light-- oil pressure = 0 cueball TJ Wrangler Technical Forum 6 08-29-2010 04:59 PM
low oil pressure and check gauges light.... jurob TJ Wrangler Technical Forum 8 08-29-2010 03:52 PM
Check Gauges Light/Oil Gauge Toady TJ Wrangler Technical Forum 4 06-23-2008 08:01 PM
“Check Gauges” light on, Oil Pressure Gauge at 0 CobraKhan TJ Wrangler Technical Forum 6 08-30-2004 10:50 AM
