installed locker last night...but scared...should i be?? - JeepForum.com
post #1 of 5 Old 02-04-2004, 10:05 PM Thread Starter
jackal
jackal's Avatar
I installed my front locker last night...but i'm really scared that i'm going to break something now. I tested that sucker out by climbing a tree...yes..climbing a tree. There aren't very many rocks and stuff where I live so...that's about as best as I could do. Is there a good chance of breaking an axle or axle u-joint by just climbing stuff like that...or like little boulders or someone elses tire? Also...does it really put a lot of stress (ABOUT TO BREAK) when the wheels are turned? I run 33x13.50 and have the dana30 front. Thanks. BTW...no locker in the back yet.
JackaL
Green Jeep Club Member # 68
97 Jeep Club MEMBER # 1
1997 4.0L Wrangler TJ 5 spd. 4.56 Locked&Loaded up front..., Remote Start,
Poweraide Throttle Body Spacer,
BanksPower Stinger CAT-BACK,
Advanced Adapters SYE kit
Krylon Fusion Flares!
Skyjacker Dual Steering-Stabilizer
R.E. 5.5" Long-arm Coils
1" Body Lift,
37" MT/Rs on 15"x10" wheels
If they ain't singin'...they ain't slingin'!!
$1000 sound system inside!
jackal is offline
post #2 of 5 Old 02-04-2004, 10:16 PM
JeepCrawler_98
JeepCrawler_98's Avatar
That Dana 30 will be fine with 33"s. A friend of mine has a 4.0 YJ with a Detroit up front, 4:56s, and 35"s TSLs. He has a crazy right foot - he goes through a U-joint every few months, but I'm sure that with 33"s and care you'll be ok. This friend of mine is more of a "Floor it now - fix stuff later" kind of driver.
Also keep in mind that down in AZ the trails are just crazy with rock obstacles. Any obstacle down here is definitely maxing it out as far as torque stresses are concerned.
New kid on the block!:
JeepCrawler_98 is offline
post #3 of 5 Old 02-04-2004, 10:21 PM
Graphic
Well, I would like to say I know JackaL in real life. ( Talk about a ugly whiteboy) Anyhow, I think you guys should give him opinions because he doesn't know what he's doing.
Plus he ditches me and testing out the locker... for his 'girlfriend'
Bros before hoes
Graphic is offline
post #4 of 5 Old 02-04-2004, 10:21 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Remember that the u-joints are at their weakest when the wheels are turned to the left or right and you should be ok. My u-joint busted and took the passenger-side axle shaft with it when I attempted to crawl over a boulder on Sledgehammer when I forgot my steering wheel was still cranked all the way over after having been parked in that position for 15-20 minutes.
Jerry Bransford is offline
post #5 of 5 Old 02-04-2004, 10:39 PM
Bighaeb
Bighaeb's Avatar
Try to apply the skinny pedal when going in a straight/semi straight line. If you must turn sharply with that locker, just take it easy when engaged and you'll be OK. Happy trails! Time to get the rear locker now!
"Rigged for her pleasure"
Jeepless for now
Bighaeb is offline
Ox Locker installed N2rock JK Wrangler Technical Forum 22 10-24-2013 12:50 AM
Aussie Locker installed finally. TinkerAB TJ Wrangler Technical Forum 11 01-19-2010 10:58 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
Installed lift last night madapple33 TJ Wrangler Technical Forum 4 10-13-2006 10:12 AM
Locker Installed wasaw YJ Wrangler Technical Forum 5 03-26-2005 07:09 AM
