Installation of Smittybilt rear bumper is driving me crazy... - Page 2 - JeepForum.com
post #16 of 39 Old 07-12-2010, 09:13 AM
cyberiv
I put on the smittybuilt rear with tire carrier, it was a pain, and took lots of drilling, but i dont have a body lift and didn't have to drop the gas tank. Look up the rugged ridge installation instructions, its the same bumper, but i used those instructions instead of what came with it as they were alot easier to understand and went into a lot more detail. Just make sure you buy extra grade 8 harware and lots of washers for the nut/bolts that don't offer much clearance (i.e. inside frame). I also suggest the rockmen frame tie-in's since you are under there anyway.
cyberiv is offline
post #17 of 39 Old 07-12-2010, 10:55 AM Thread Starter
wranglerWestLA
Finally a good tip!
thank you very much.
I will try to find what you suggested.
Don't you have pics by any chance of the installation?
Thanks again!
wranglerWestLA is offline
post #18 of 39 Old 07-12-2010, 11:43 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by rob78 View Post
"Well, on the TJ model, the first thing is to take off the gas cap, then push down on the little valve inside the gas filler neck to release any pressure in the tank.
1. There is no "little valve" inside the filler neck.
2. You just took the gas cap off, how would there be any pressure in the tank?...
Knuckelhead is offline
post #19 of 39 Old 07-12-2010, 12:04 PM
cyberiv
Originally Posted by wranglerWestLA View Post
Finally a good tip!
Thanks again!
Here is a link to the rugged ridge instructions...
http://www.omix-ada.com/instructions/11503.11.pdf
i didnt take pics of the install, but i can take a few for you of what it looks like on the jeep when i get home from work tonight...
cyberiv is offline
post #20 of 39 Old 07-12-2010, 12:24 PM
danielbuck
1946 CJ2
Originally Posted by Couchrider View Post
$90/hour is insane.
I think that's a pretty normal shop and dealer rate for working on a vehicle.
danielbuck is offline
post #21 of 39 Old 07-12-2010, 12:31 PM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
All you have to do is take a drill and elongate the holes in the rear support where necessary. It wasnt that bad - be sure and use the frame tie-ins...
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #22 of 39 Old 07-12-2010, 01:03 PM Thread Starter
wranglerWestLA
Cyberiv:
Thanks but that is not the bumper I got.
Mine is the classic one, with tire carrier and D rings.
This one looks much easier to install cause you tighten the bolts from the outside into the frame.
In my case you have to tighten them from the rear part of the frame into the bumper.
That is why it is tricky.
post #23 of 39 Old 07-12-2010, 08:14 PM
kuruma
I'm glad I have an LJ good luck getting that sucker on. You may need a little lube to get the bolts to run but just torque them down good and you should be set. All this is assuming you can get access to the frame though.
kuruma is offline
post #24 of 39 Old 03-31-2011, 04:30 PM
iplumb
so what did you end up doing?
iplumb is offline
post #25 of 39 Old 03-31-2011, 04:34 PM
Night Wolf
FWIW here is a write-up I did of installing my rear bumper - LoD Xtreme, an excellent product which I am Xtremely happy with.
http://www.jeepforum.com/forum/f9/lo...lation-821783/
-Rick
-1987 BMW 528e 5spd e28 - personal Panzer for the daily driven battlefield, just broken in at 300k
-1990 BMW 325i Convertible 5spd e30 - extensive overhaul in progress
-2005 TJ Sport - stuff
Night Wolf is offline
post #26 of 39 Old 03-31-2011, 05:47 PM
dwine7274
Thank you.
Before I attempt to drop the fuel tank, I d like to hear from someone that installed this bumper if they have any tip/suggestions.
I will check the video right now.
Dropping the tank takes about 15 minutes and saves you tons of time fighting to get your hands behind that cross member. Just put a piece of plywood on top of a jack and lower it, you do not need to fully disconnect the tank, just dont let the jack drop it. I did make sure my tank was almost empty. I only unscrewed the bezel around the gas filler neck, I did not have to undo any of the actual gas lines.
dwine7274 is offline
post #27 of 39 Old 03-31-2011, 06:14 PM
JeepGuy813
If I were you id save up a little more money, so when you drop the gas tank you can replace the old skid with a nice savvy one...
1995 Jeep Wrangler Yj = SOLD
1999 Jeep Grand Cherokee WJ = SOLD TO PARENTS
1997 Jeep Wrangler Tj = SOLD and missed alot
JeepGuy813 is offline
post #28 of 39 Old 03-31-2011, 07:16 PM
iplumb
OK Not real happy! Just started dropping my skid and after letting the tank straps soak with PB blaster I snapped the straps. So whats next? Anybody know of a good write up on dropping a tank to replace these straps? Where do they even go? never dropped a tank before. Is there enogh play in the fuel line? I did remove the screws around the filler neck. HELP!
iplumb is offline
post #29 of 39 Old 03-31-2011, 07:22 PM
iplumb
Now as I look around on the net I see I didn't even have to mess with those straps....Do they just hold the tank down to the skid? Can I get new straps?
iplumb is offline
post #30 of 39 Old 03-31-2011, 07:23 PM
iplumb
Looks like its part of the tank in this photo.
iplumb is offline
smittybilt , rear , bump , install , tj , wrangler
Smittybilt SRC JK Rear Bumper muttytruckster JK Wrangler Technical Forum 7 02-17-2011 06:33 PM
Installation of MetalCloak Overline Fenders/Front & Rear Smittybilt XRC Bumpers n3wdeal TJ Wrangler Technical Forum 7 06-08-2010 11:48 PM
smittybilt xrc rear bumper ClassicRiderhp TJ Wrangler Technical Forum 7 03-05-2010 11:20 AM
Smittybilt Bumper Flexing Like Crazy MrKing TJ Wrangler Technical Forum 28 03-02-2010 12:07 PM
smittybilt bumper installation questions jeepbro's TJ Wrangler Technical Forum 26 04-18-2008 09:52 PM
