Installation help with Rough Country lift - JeepForum.com
post #1 of 8 Old 07-17-2010, 01:39 AM Thread Starter
johnxjeep
They told me to remove one shock at a time when installing me 2.5 lift kit.
I did it this way for the rear. I will install front on Saturday.
Do I need to remove 1 shock at a time and do 1 side at a time like this.
The rear was sort of a PITA. It seems easier to let the whole axel down remove springs and replace.
Thanks.
BTW Springs and shocks.
johnxjeep is offline
post #2 of 8 Old 07-17-2010, 02:29 AM
rs4race
just let the whole axle down. It will make it much easier to install the springs. Also dont drill your trackbar bracket until after you measure how far your tires are off.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #3 of 8 Old 07-17-2010, 05:49 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
I used jackstands and removed both shocks.
TheBoogieman is offline
post #4 of 8 Old 07-17-2010, 05:56 AM Thread Starter
johnxjeep
Is there a specific top and bottom, or does it matter ?
post #5 of 8 Old 07-17-2010, 05:59 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the shocks can only go in one way, if the bar pins are already pressed in its obvious.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 8 Old 07-17-2010, 07:44 AM
UTWeezul
If you have the RC 2.2 shocks the can goes up just in case the bar pins are not pushed in...but they should be.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #7 of 8 Old 07-17-2010, 08:20 AM Thread Starter
johnxjeep
I am sorry.
It is the coil springs in question
post #8 of 8 Old 07-17-2010, 11:33 AM
TheBoogieman
Deeply Disturbed
I am sorry.
Check out the RC springs to stock and you will know.
install , installation , lift , rc , rough country , shock , tj , wrangler
ROUGH COUNTRY LIFT = REALLY ROUGH RIDE? Why? pjleslie03 TJ Wrangler Technical Forum 32 01-02-2011 01:02 PM
4in Rough Country Lift installation Tips petersyj95 YJ Wrangler Technical Forum 11 02-01-2009 08:30 PM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
Rough Country 4" installation Topgun514 TJ Wrangler Technical Forum 4 04-15-2008 05:22 PM
Rough country 4 inch installation MRemp TJ Wrangler Technical Forum 2 02-11-2007 10:08 AM
