Inputs needed on PSC Steering Box and Pump. - JeepForum.com
post #1 of 4 Old 07-30-2010, 12:57 PM Thread Starter
MountainMan864
My Powersteering pump is shot and my steering box is leaking and moaning like a SOB. I looked up PSC because I read that they rule the world in steering. I know they are expensive though. Are the boxes bolt on? I am only running 33's atm but in the next 2 years or so, im gonna step it up to 35's when money for a d44 arrives and sye/ca's/etc. Would this box be overkill. I add to completly fill up the resevoir everyday and that gets expensive quick, been doing it for several months now. Could I go with just a PSC Box and use an O'reillys pump or do they have to match? Thanks guys.
MountainMan864 is offline
post #2 of 4 Old 07-30-2010, 04:20 PM
pwcracer
Xtreme 4x4 just put one of these on their TJ a couple of weeks ago. The psc pump was a direct replacement for the stock jeep pump.
pwcracer is offline
post #3 of 4 Old 07-30-2010, 08:53 PM Thread Starter
MountainMan864
Yea i know it is but you need a cooler and a resevoir too and lines and stuff. like the kit costs $400 and then prob the box is gonna go out and thats another $400 then install cost is proably gonna be 200 or so. I little much right now, I think ill just try my luck and get another one from O'reillys
post #4 of 4 Old 07-30-2010, 09:44 PM
2005X
they make direct bolt on steering box similair to the dodge durango box or even stock box, or you can upgrade like i did to a bigger and better system that includes the pump, remote reservoir, pully and of course the hoses/clamps. i also went with the cooler cause the ambient heat from the I6 and low speeds on the trails in 100 degree and high humidity was causing air bubbles in my line.
2005X is offline
psc , steering box , pump , advice , tj , wrangler
Power Steering pump leaking pink liquid - can the pump be fixed, or replaced? Sparty TJ Wrangler Technical Forum 10 01-13-2010 11:29 PM
Is the steering shaft needed for power steering conversion? tr196 YJ Wrangler Technical Forum 6 04-27-2009 07:32 PM
Leaky Power Steering Pump and Steering Clunk. KATSTJ TJ Wrangler Technical Forum 6 01-03-2009 06:03 PM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 04:23 PM
Chevy Power Steering Pump / Jeep Steering Box ? glenno YJ Wrangler Technical Forum 8 01-16-2008 02:40 PM
