Input/Advice on suspension lift/BL plans - JeepForum.com
post #1 of 12 Old 09-19-2009, 01:12 PM Thread Starter
MikalCarbine
After much thinking I've changed where I want to go with my lift. A friend helped me pick this:
Jeep TJ Suspension Lift
Basically the progressive 2.5" RC lift with a 1-1/4" BL.
I plan on getting this and a new front/rear adjustable track bar (probably JKS, RE or Currie Rock)
The kit comes with transfer case spacers so I don't need to worry about vibes (hopefully)
Is there anything else I should think about ordering along with this? Eventually I'll be going with 33's (skipping my 31's idea before). Would a MML be necessary with the BL?
MikalCarbine is offline
post #2 of 12 Old 09-19-2009, 01:15 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
a BL would be necessary to run 33s, and you may be able to avoid the t-case drop by installing the MML. you may end up stacking a few washers if you get vibes, but at least it won't be a large t-case drop.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 12 Old 09-19-2009, 01:17 PM
Contra
i did the MML, body lift and suspension lift
all turned out well too
Ever Gone Geocaching?
Contra is offline
post #4 of 12 Old 09-19-2009, 01:18 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You don't need a rear adjustable track bar.A $17 bracket will work.Why not buy the RC front track bar?You need to see if you have vibes before installing the t case spacers.A MML might fix any vibes without the t case drop.It has nothing to do with installing a BL.
TheBoogieman is offline
post #5 of 12 Old 09-19-2009, 01:18 PM
jmasin
OP, that's pretty much what I'm working toward too, sounds like a good plan
'03 Sport, Patriot Blue
'04 C5 Corvette
jmasin is offline
post #6 of 12 Old 09-19-2009, 01:29 PM Thread Starter
MikalCarbine
So I'll skip the rear trackbar and get a bracket. I checked out RC front trackbars but they seem flimsy and I'd rather spend a little extra for something better. JKS and RE can be had for about 140-200ish
The calculated damage so far:
RC 2.5" Lift with 1-1/4" BL ~$400
Front Track Bar ~$200
Rear track bar relocation bracket ~$20
So I am looking at about 600 +/- which means I should be able to buy it sooner than expected
post #7 of 12 Old 09-19-2009, 01:44 PM
Riot
Install the suspension and body list.
Give it some time to see if you need the T-case drop. If you do- Install it.
If that still doesn't work, i'd continue to look for other answers, but I wouldn't worry about it that bridge until you have to cross it.
2001 XJ, 3.5" RE Lift, HP d30/29s 8.25, 33" BFG All Terrains, Custom Front Bumper.
Riot is offline
post #8 of 12 Old 09-19-2009, 01:55 PM
TheBoogieman
Disturbed
The new RC front adjustable track bars are very sturdy.
post #9 of 12 Old 09-19-2009, 01:56 PM
TheBoogieman
Disturbed
You will know that 2 minutes after installing the lift.
post #10 of 12 Old 09-23-2009, 07:50 PM
Riot
Hey man!
Order this yet!? ;]
Riot is offline
post #11 of 12 Old 09-23-2009, 09:54 PM Thread Starter
MikalCarbine
Hopefully 2 weeks
post #12 of 12 Old 09-23-2009, 11:05 PM
rubidriver
Only time will tell if that statement is true.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
Advice on buying suspension lift GAjeep TJ Wrangler Technical Forum 19 01-22-2010 02:15 PM
future plans, input please... kbarwall TJ Wrangler Technical Forum 12 01-21-2010 02:55 PM
Need advice on which suspension lift to buy Janfri YJ Wrangler Technical Forum 3 02-12-2009 11:53 AM
3-3.5" lift, need some input/advice on things (full traction kit) NJHCx4xLIFE TJ Wrangler Technical Forum 7 12-24-2008 12:47 PM
input on my plans brantb YJ Wrangler Technical Forum 10 10-24-2007 07:25 PM
