Inner Tube Seal Question Rubicon Dana 44 - JeepForum.com
post #1 of 13 Old 07-13-2010, 04:56 PM Thread Starter
Sallad
2014 JK Wrangler
Hello JF, so I need to change my inner tube seals on my front axle. My jeep is a 04 Rubicon so it would be done on a D44. I went to the dealership to get my seals and they sold me two seals (might as well do both) but they also sold me these white plastic "guides". I read alot of different write ups on how to do the seals but I havn't seen one use these white guides. Anyone know what they are for?
They matched up the part with my VIN.
Thank you for reading.
Sallad is offline
post #2 of 13 Old 07-13-2010, 06:32 PM
littledevilTJ
take a picture of them. i have no idea what your talking about.
My OLD build thread:
Florida Specific Forum
littledevilTJ is offline
post #3 of 13 Old 07-13-2010, 06:44 PM Thread Starter
Sallad
2014 JK Wrangler
Yea that would prob be best.
Sallad is offline
post #4 of 13 Old 07-13-2010, 07:11 PM
MikeBK
the white plastic rings go on the axle at the inner spline end to keep the axle centered so you don't rip the new seals, I just did mine in my 04 Rubicon last weekend.
Consider Obama the lesson many in this country need to learn, the rest of us just have to pay for it!
MikeBK is offline
post #5 of 13 Old 07-13-2010, 07:17 PM Thread Starter
Sallad
2014 JK Wrangler
Sallad is offline
post #6 of 13 Old 07-13-2010, 07:19 PM Thread Starter
Sallad
2014 JK Wrangler
Do they stay in there or are they just for installation?
Sallad is offline
post #7 of 13 Old 07-13-2010, 08:18 PM
mudb8
want it rite or rite now?
mudb8's Avatar
slide them over the splines of the axle, they tend to shove the dirt and crap laying in the axle tube against the new seal.... unless of course you take the extra time to clean it all out.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #8 of 13 Old 07-13-2010, 09:24 PM
littledevilTJ
and you should really take the time to clean the tubes out.
post #9 of 13 Old 07-13-2010, 09:48 PM
Hella
did mine not to long ago too and they sold me them things. I didnt end up using them because I didnt have the axle shafts in when I did the install. I dont have the special press thing or whatever. So I have a few long extensions and a socket I used through the tube to press them in. Worked perfect...and just be careful when you slide the axle shaft back in, if you go this route
04 TJ "Leyla" Rubi..
Hella is offline
post #10 of 13 Old 07-13-2010, 10:49 PM Thread Starter
Sallad
2014 JK Wrangler
Thanks all for your replies. Yea I dont have a fancy press either and will take the time to clean the tubes as they are filthy.
Sallad is offline
post #11 of 13 Old 07-14-2010, 10:07 AM
Hella
Yeah and when I did my inners I cleaned the tubes and also bought a set of Superior Axle outer axle seals. They are pretty nice IMO, should help protect the inners better
Hella is offline
post #12 of 13 Old 07-14-2010, 04:50 PM Thread Starter
Sallad
2014 JK Wrangler
Yea i was thinking about purchasing those as well just not 100% sure. Some people say get em and some say its not worth it.
Sallad is offline
post #13 of 13 Old 05-02-2013, 07:26 PM
joshn
can you tell me the part number by chance for them? does something ending in "AB" sound familiar?
joshn is offline
Rubicon , inner , axle , tube , seal , Dana 44 , front
dana 30 axle seal question..... jeepin1995 YJ Wrangler Technical Forum 2 03-12-2009 06:13 PM
Dana 30 seal diameter Question 95wrangler4life YJ Wrangler Technical Forum 9 02-17-2009 02:45 PM
dana 44 yoke oil seal question hecubus TJ Wrangler Technical Forum 3 12-02-2007 04:48 PM
Dana 30 seal question JPH YJ Wrangler Technical Forum 2 03-04-2005 12:41 PM
dana 30 axle tube seal upgrade bailey TJ Wrangler Technical Forum 4 11-01-2004 09:29 AM
