info electricals TJ - JeepForum.com
post #1 of 9 Old 11-06-2007, 05:54 AM Thread Starter
giacomo.m
info electricals TJ
Hi all,
does anyone have a wiring diagrams of the PDC for the TJ 4.0 1997 ?
thank you.
Giacomo
giacomo.m is offline
post #2 of 9 Old 11-06-2007, 09:03 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I do but the schematic is spread out over MANY pages, the PDC isn't grouped together, the various circuits that pass through the PDC are described separately. Better you buy a used 1997 Factory Service Manual on eBay or similar.
Jerry Bransford is offline
post #3 of 9 Old 11-06-2007, 09:50 AM Thread Starter
giacomo.m
Hi Jerry ,
thank you for your answer.
my problem is fuse ID,on the lid of the PDC it says refer to the owners manual,but in the owners manual it says the locations are clearly marked in the PDC itself.
Giacomo
post #4 of 9 Old 11-06-2007, 09:52 AM
Jerry Bransford
Administrator
Post up the fuse ID you need identified and I'll look it up tonight when I get home from work, or someone else may during the day.
post #5 of 9 Old 11-06-2007, 09:59 AM Thread Starter
giacomo.m
I have all gauges of instrument cluster and lights off.
why ? I have already controlled in fuse block behind the glove box,but all ok.
Giacomo
post #6 of 9 Old 11-06-2007, 01:09 PM
AMLechner
Jerry,
is it possible for you to tell me what the pin positions are for on the defrost (1 - 4) and rear wiper (1 - 6) switches. I know the orange ones are for the illumination, just not sure about the rest.
Thanks,
Adam
Penn State University - class of 2004
AMLechner is offline
post #7 of 9 Old 11-06-2007, 01:13 PM
Jerry Bransford
Administrator
I would Adam but I am not so sure I'd trust my FSM's '97 schematics are accurate for your 2004. But I can at least look at the schematic tonight when I get home, perhaps at least the wire colors are the same. PM me so I won't forget.
post #8 of 9 Old 11-13-2007, 12:56 AM Thread Starter
giacomo.m
Hi Jerry,
the 2 fuses that I would want to identify to the inside of PDC : F19/10A and other from 10A.
thank you.
Giacomo
post #9 of 9 Old 11-13-2007, 06:05 AM
ROUGHSHOD
ROUGHSHOD's Avatar
Originally Posted by AMLechner
Jerry,
Thanks,
Adam
Didn't my post here help you at all?? From my 2006 FSM...
ROUGHSHOD is offline
need lift info & regearing info stuart2410 JK Wrangler Technical Forum 3 01-18-2009 09:28 AM
need info on cps on 89 i6 lee95yj YJ Wrangler Technical Forum 1 09-01-2008 06:01 PM
Steering Wheel Electricals Not Working Rubi22 TJ Wrangler Technical Forum 5 03-22-2007 11:39 PM
need some info on 93 2.5 wooten YJ Wrangler Technical Forum 3 02-13-2006 06:49 AM
Factory Warranty info? Top info? BlueRidgeRunner TJ Wrangler Technical Forum 5 06-27-2004 03:52 PM
