The Infamous Manifold - JeepForum.com
post #1 of 8 Old 12-24-2007, 02:04 PM Thread Starter
Wynne
Well, my manifold finally gave up on me. It is cracked about 10 inches from where it meets the exhaust pipe. It is only about half cracked. I am going to order a new one, but it might take a little while due to the holidays and need my Jeep. I have heard of some type of exhaust tape that can be wrapped around. Does anyone have any experience with this? I have to go to school next week and its a decent drive there and might have to put it on after the drive. Let me know what anyone knows about the tape or any suggestions. Thanks alot guys.
P.S. I found a new one on Ebay which I used to replace the cracked one on my old TJ for around $88 shipped. Let me know if anyone has another website for one.
1998 Sahara- Budget Boost, 33x10.50 BFG A/T, Rear D44(Powertraxed), Flowmaster 40, Warn XD9000i, JKS 1.25" BL & 1" MML, Warn Oil Pan Skid
Wynne is offline
post #2 of 8 Old 12-24-2007, 02:21 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Make sure that eBay header (it's a header, not a manifold) you found for $88 is not just an one that had a crack welded up. The type of header to stick with has a flexible accordian-joint added at each of the two points where the OE header tends to crack at.
Jerry Bransford is online now
post #3 of 8 Old 12-24-2007, 04:43 PM
cj847
I bought an $80 odd dollar exhaust off of ebay about a month ago. It has the accordian joints. Installed fine and has been working great (I even used the China gaskets).
In the interim, I would just drive it. Just don't sit in it with the jeep idling for 20 minutes. It should be OK.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #4 of 8 Old 12-24-2007, 04:48 PM Thread Starter
Wynne
http://cgi.ebay.com/ebaymotors/97-98...spagenameZWDVW
This is the one I found, it has the accordian parts, but they aren't where mine broke.
Wynne is offline
post #5 of 8 Old 12-24-2007, 04:57 PM
Jerry Bransford
Administrator
As long as it has the two accordian joints, and the one in that photo does, it should be fine.
post #6 of 8 Old 12-24-2007, 07:08 PM
creaky70
I purchased the same manifold from EBay about a year ago. It appears to be good quality, fit perfectly and has not given any problems in a year of driving. The gaskets, however, were completely bogus. I pitched them and used a Felpro manifold gasket and a ?? donut gasket from NAPA.
creaky70 is offline
post #7 of 8 Old 12-25-2007, 08:30 PM
travislakerat
I just replaced one on a 99 TJ about 4 months ago and the funny thing is, the one I replaced was just like the one I bought on ebay. Regardless, it fixed it and I sold the jeep. Hopefully the new exhaust will last you for a good while.
2011 F250 Superduty
2007 C6 Convertible Vette
1997 Jeep TJ
travislakerat is offline
post #8 of 8 Old 12-26-2007, 06:25 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by creaky70
...The gaskets, however, were completely bogus. I pitched them and used a Felpro manifold gasket and a ?? donut gasket from NAPA.
Good point.
The gaskets that come with those cheap headers is questionable.
An OE gasket will run you about $15 from the dealer and its raised around the ports for a better seal.
Wheelin98TJ is offline
The Infamous code 51????? sutbag TJ Wrangler Technical Forum 5 01-17-2010 07:29 PM
Fixing the infamous TrailJammer whistle ***write up*** Squeeky TJ Wrangler Technical Forum 12 01-14-2008 05:30 PM
So where is the infamous blower motor fan? - to fix water leak ppark TJ Wrangler Technical Forum 4 07-01-2006 06:45 PM
The infamous gas tank sending unit problem on 97 TJ nmarsh TJ Wrangler Technical Forum 25 02-10-2005 11:16 AM
The infamous Check Engine light... Darkus TJ Wrangler Technical Forum 1 12-24-2003 08:59 AM
