The Infamous code 51????? - JeepForum.com
post #1 of 6 Old 01-17-2010, 03:47 PM Thread Starter
sutbag
ok guys, finally got my jeep running again since my last post a couple of days ago. Everything i thought was fine, but now i have the infamous code 51. I know what most of you will reply so save the o2 sensor speech. Here is what i did so far:
replaced BOTH O2 Sensors about 5 times
replaced MAP sensor
replaced exaust manifold
replaced cat
cleaned throttle body
new spark plugs
new rotor
new cap
new wires
Next i think im going to check for vac leaks, any other ideas????
Gas Cap? Gas tank bleeder valve? i'm almost ready to sell the damn thing.
thanks!!!!!
sutbag is offline
post #2 of 6 Old 01-17-2010, 05:50 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You have OBD-II, right ? Why not stop by the auto parts store and borrow their Check Engine Light trouble code reader and download the codes ? Pxxx OBD-II codes are much more specific about the malfunctions than the generic codes like 51, and will help you focus your troubleshooting.
Have you inspected the wire harness and wire plugs for your O2 sensors. If you have a good O2 sensor but bad O2 sensor wires, the ECM can't tell the difference. Look for broken wires, chafed or burned wire insulation, and short circuits.
CJ7-Tim is offline
post #3 of 6 Old 01-17-2010, 05:55 PM
finalreckoning
No, he has obd, not obd II
His is 97, we don't get that luxury :P
Green Jeep Member #273
High School Jeepers #169
finalreckoning is offline
post #4 of 6 Old 01-17-2010, 05:58 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
IIRC all 1996 vehicals and up have OBDII?...
Knuckelhead is offline
post #5 of 6 Old 01-17-2010, 06:33 PM
black71gp
2009 JK Wrangler
Yes 97's have OBDII they just use the older number system instead of the newer "PO" style. is the code causing it to run bad after fixing all those issues?
black71gp is offline
post #6 of 6 Old 01-17-2010, 07:29 PM
demon67
wait a sec. I have a 97 TJ and mine is obd2
demon67 is offline
Fixing the infamous TrailJammer whistle ***write up*** Squeeky TJ Wrangler Technical Forum 12 01-14-2008 05:30 PM
The Infamous Manifold Wynne TJ Wrangler Technical Forum 7 12-26-2007 06:25 AM
So where is the infamous blower motor fan? - to fix water leak ppark TJ Wrangler Technical Forum 4 07-01-2006 06:45 PM
The infamous gas tank sending unit problem on 97 TJ nmarsh TJ Wrangler Technical Forum 25 02-10-2005 11:16 AM
The infamous Check Engine light... Darkus TJ Wrangler Technical Forum 1 12-24-2003 08:59 AM
