The infamous Check Engine light... - JeepForum.com
post #1 of 2 Old 12-24-2003, 06:43 AM Thread Starter
Darkus
I bought a '97 with 67k miles on it. It has a four-cylinder.
If the engine is idling for an extended period (10-15 minutes or so) the light comes on.
When I dump the code, I get 12-31-55.
I know what the 12 and 55 are, and the code lookup says that the 31 is "EVAP purge solenoid circuit".
I also know that the device itself may not be the problem, but I don't know what it looks like or where in the engine compartment it is, so I don't know where to start de-bugging. The Haynes manual is no help, since it shows a different year, and not the location.
If anyone can point me to it, or post a pic of it, it would be most appreciated.
Darkus is offline
post #2 of 2 Old 12-24-2003, 08:59 AM
4wd-racer
4wd-racer's Avatar
Im sure someone will chime in. My FSM is still on the way. Havent had any problems so far, but Id like to have one just for the reason you would like one now.
'03 Jeep Sahara, 242ci engine, 4-speed AT, Dana 30/Dana 35 w/ LS, 3.73s, K&N, 2" Procomp lift, 15" Cragars w/ 32" Dunlop MTs, banks exhaust.
4wd-racer is offline
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 01:19 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
O/D Light Not Working & Check Engine Light On JeepMom2 TJ Wrangler Technical Forum 2 12-24-2006 08:43 AM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 04:48 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
