#1 | |
increase tire size with out a lift
i have recently bought a '05 wrangler and could not be happier. so much fun. it is almost time to put new tires on it and i think it would look a lot better with a little bigger tires. however i want to keep it as compfrotable as possible as a daily driver (i ant to drive it all the time). can i increase the tire size with out a lift??
#2 |
ECTR Co-Founder
you can go as large as a 30x9.50r15 on those wheels. If you wanted to go to a 31x10.50R15 you would need either wheel spacers or after market wheels.
But the simple answer is, you can go as large as a 31x10.50 with no lift.
Jake Davis 97 Jeep Wrangler 4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery. 1987 Jeep Grand Wagoneer 360/727/229/D44/D44/31x10.50 East Coast Trail Raiders Wilmington weekly 4x4 meet |
#3 |
it's stock...i swear
You can run 31's with no lift. Factory Rubicon's come from the factory with 31's but do have slightly different backspacing on their factory wheels.
Congratulations on the Jeep purchase.
Justin 2004 Jeep Wrangler l 1971 Chevrolet Chevelle l 1988 BMW 325 l 2009 Triumph Thruxton |
#4 |
ECTR Co-Founder
actually their back-spacing is pretty close to the same, the main difference is they are running an 8" rim and have a tire that only measures 10" wide at the most. Really it's the only reason why jeep went with a 16" wheel, so they could get the height of the tire but keep it skinny enough to run the standard BS with out rubbing on a CA.
#5 |
if you bust out the sawzall and cut the body up, you can fit 35x12.50's on 4" of backspacing. otherwise 31x10.50.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Knuckle Brake Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#6 | |
#7 | |
American Expedition Vehicles - Highline Body Kit - 97-06 Jeep Wrangler (TJ) Conversion Kit
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather. [Edit] "Now jeepin in Oregon" [/Edit] |
#8 |
Or DIY Highline...
DIY High Line Hood Mod for cheap : Higher Ground 4×4 |
#9 |
I put 31x10.5 tires on my 05 Wrangler,and new wheels also,it does not have a lift,and it still rides like factory...I cannot post picture,but there is one photo on my profile....
Buford |
#10 |
or metalcloak fenders.... there's a guy around here with them runnin 33's no lift and it looks good
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs and MX6 Adjustable Shocks, 37" Iroks |
#11 |
Bit**es get stitches
The largest tires I'd run on no lift are 35's. Either DIY highline, AEV, Metalcloak, or TNT fenders. When the time comes, I'll be running 40's on 2.5" of lift with a 1" body lift (current amount).
#12 | |
2006 Golden Eagle; V-8 ZJ front springs with 2 1/2" spacer in front, stock front coils in rear; 1.25" BL; 1" bmml; 33x10.50 BFG KM2's; 1 1/2" RC wheel spacers; Full Boar muffler; Rough Country steering stabilizer; 4WD Hardware Hydro's ; dent in fender by deer hoof; rocker damage by Yellowjacket; AEM filter on stock tube; HF 9000lb. winch |
#13 |
Nice looking TJ, it will look good with a little more tire under it, but it will look even better if you spend an extra 30 seconds to fold your top a little neater
#14 | |
Me=top nazi. Do it right. |
#15 | |
![]() To the OP, I just want to make sure theres no hard feelings here, just a little joking around, welcome to the forum! ![]() |
| Thread Tools | |
| Suggested Threads |
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
