im so pissed!!! - JeepForum.com
post #1 of 29 Old 04-20-2007, 08:07 PM Thread Starter
bloke279
bloke279's Avatar
2015 JK Wrangler
im so pissed!!!
My full traction three inch came with a TC drop. I wasnt to extremely excited about it, but it wasnt a big deal! now my tc wont stay i 4 lo, even after adjustment, under high torque.
Climbing a modest hill today, i had to stop while in 4 lo. When i started forward again, i held the brake with my left foot, and gassed it with right for a smooth take off. Almost immedietly, the TC popped out.
Does it need more adjustment, or is there another solution i need to chase?
2015 JKU
BB, Rubi wheel/tire, Barricade sliders
Ordered:
Synergy Ball joints, gussets and sleeves
Saving for:
4" short arm, 35's, bumper/carrier, e-locker and gears
bloke279 is offline
post #2 of 29 Old 04-20-2007, 08:11 PM
KUK9
KUK9's Avatar
Check underneath and see if anything is binding up- do this before anything. Might just be something got knocked outta whack.
Did you actually put the TC drop on? I can't really tell from your post. If so, try taking it off and see if your linkage works fine again. If so, try driving around and see if you have vibes. You might have dropped it too far, possibly making the linkage not work correctly. Not really sure what else to try.
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline
post #3 of 29 Old 04-20-2007, 08:16 PM
elkfan2
elkfan2's Avatar
Did you get a bracket to lower the shift linkage where it ataches to the body. Whem I first installed my bb it didn't come with the bracket to lower the linkage also and mine would do the same thing.
elkfan2 is offline
post #4 of 29 Old 04-20-2007, 09:06 PM
xjeepn
xjeepn's Avatar
I am having the same problem! I am taking my body lift off to see if that helps. I guess we could buy a Novak shifter and be done with it.
05 X with 4.0 auto with 3" Full Traction Lift with 3/4 spacers up front, Warn M8000 winch, Hella 500 driving lights, Cobra CB with Wilson 4 ft antenna, 48" Highlift Jack, tow hooks on all corners, 2 fire ext, 4 ft shovel, some recovery gear, AEM cold air intake dry filter and riding on 33 x 12.5 Pro Comp All terrains.
xjeepn is offline
post #5 of 29 Old 04-20-2007, 09:11 PM
freedom5
You need to add about 1" to you're TC linkage
After that it never happened again.
freedom5 is offline
post #6 of 29 Old 04-20-2007, 09:14 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
or buy the advanced adapters relocation bracket.. http://www.northridge4x4.com/proddet...prod=AA-715542
XabuJr is offline
post #7 of 29 Old 04-20-2007, 09:14 PM
MuddyJeepZJ
MuddyJeepZJ's Avatar
Yes, get rid of the POS stock shifter and install a Novak, you will be much h appier this way! I sure am.
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #8 of 29 Old 04-20-2007, 10:22 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
If you installed the TC drop then you should probably get the new TC drop bracket as mentioned earlier, or the AA one that replaces the factory one
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #9 of 29 Old 04-20-2007, 11:00 PM
XYZER
I just installed a 3/4" TC drop kit and a 2" lift. I was concerned with the same issue. I took it out and used it with no problems. I have had it pop out before the lift if I hadn't made sure it was fully engaged. Nice to know there is a good fix out there!
1998 TJ Sport 4.0L Auto
OME HD 2" lift
31x10.5 BFG's
Custom bumpers W/winch
XYZER is offline
post #10 of 29 Old 04-20-2007, 11:30 PM Thread Starter
bloke279
bloke279's Avatar
2015 JK Wrangler
I will try pulling the TC drop out. I have a little vibes now, so i think it will only make it worse, but im not sure. Im leaning more towards getting the adapter. thankss all!
2015 JKU
Ordered:
Saving for:
bloke279 is offline
post #11 of 29 Old 04-21-2007, 12:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
All you should need to do is loosen the bolt shown in post #5 above and adjust the rod so it engages 4Lo a bit sooner. I have never needed any fancy Novak shifter kits, t-case shifter brackets, etc. to make mine shift just fine even though I have a 1" body lift and a 1" MML along with my 4.5" RE LA suspension.
It's not always a bolt-on product that is needed to fix a problem, an understanding of the problem and looking to see if it can be adjusted out is often a better solution.
Jerry Bransford is online now
post #12 of 29 Old 04-21-2007, 01:50 AM
ChiliPalmer
I wish mine was that way; I tried adjusting that thing 6 ways from Sunday but never could get it to stick. I ended up just fabbing my own drop bracket for the linkage and it works like a charm...
Forum!
post #13 of 29 Old 04-21-2007, 06:15 AM
laughinglarry
The FT 3" lift seems to be a good lift. I had to put all the TC spacers on it and my shifters do the same thing. I figured the weak point is the short drive shaft anyway so I'm putting the SYE on and getting rid of the TC drop. That puts everything back where it belongs.
laughinglarry is offline
post #14 of 29 Old 04-21-2007, 06:28 AM
GringoLoco
GringoLoco's Avatar
You still got off easy. My 3" FT lift gave me such wicked vibes, that now even with the full transfer case drop and 2 extra washers on each one, it STILL hops and shakes if I don't baby it off the line in 1st. No wheeling for me till I get a SYE. I'm just babying it around off the line and hoping I don't blow my pinion seal or anything before saving the money.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #15 of 29 Old 04-21-2007, 06:34 AM
yellj
Hope your not thinking its because it was a FT lift, you changed the height of yourJeep, it has a cascading effect, your wallet will get used to it, wait to you go to 35s, gears, lockers, shafts, steering, brakes, etc... Take it all in stride.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
Im pissed mikeb683 Wrangler General Discussion 33 12-06-2009 04:07 PM
should I be pissed? wudnme TJ Wrangler Technical Forum 19 10-08-2007 09:49 PM
ok im pissed chuckyj95 YJ Wrangler Technical Forum 7 03-17-2006 07:31 PM
My Jeep is wet and I'm pissed off... Adent TJ Wrangler Technical Forum 25 01-04-2005 01:42 AM
Anyone else pissed? slabb42 TJ Wrangler Technical Forum 2 07-27-2004 11:16 PM
