I'm not a Heavyweight!... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > I'm not a Heavyweight!...
You Pick the Size and Style of Lift Kit. We will Find you FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectDynoMax fall rebate on select mufflers!
Unread 07-04-2003, 09:44 PM   #1
Scafone
I removed the entire seat to clean the mud out the track and found all but one of the wires broken ONLY on the drivers seat. Well, I have said that the Jeep and I have been airborn a couple times.
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
Scafone is offline   Reply With Quote Quick reply to this message
Unread 07-04-2003, 10:03 PM   #2
K9JEEP
Registered Abuser
WTF?? Where did all those wires come from? I have like one behind the driver seat, and it's snaked on the floor for the Ebrake.
K9Jeep
Http://www.dso4x4.com
K9JEEP is offline   Reply With Quote Quick reply to this message
Unread 07-04-2003, 10:40 PM   #3
Scafone
I was shocked and smiling to myself when I got a load of this.
If you look under your seat, you should see them, though probably still intact.
What you can't see in the pic is there's a square shape formed by the gray cable the rusty springs are attached to. Then, there's 11 wires going straight across or horizontally in the pic to support the seat from caving in [I think]....but, it didn't feel like I was sitting in a hole, so maybe it just recently happened and hasn't had a chance to cave in. The passenger seat has them too, but all of them are fine. I ended up "rewiring" it with bailing wire.
--Thomas Jefferson
