I'm going full rightard. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > I'm going full rightard.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-14-2013, 05:50 AM   #1
joesseabee
As expected, after lifting and 33" tires to my RHD TJ with 124k miles, the trans started slipping in overdrive. Cleared the code and got back on the road with overdrive locked off. I had planned to have parts stashed next year to convert to manual transmission. I'm planning to install an ax 15 early in the spring. I was raised by a transmission shop owner, should be a piece of cake.
MM2/SS USN; CM1/SS USNR
Stop and smell the Mud.
2003 RHD 4.0 TJ postal / 1997 4.0 YJ (son's)
joesseabee is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 05:53 AM   #2
joesseabee
It's had a noisy planetary for 6 months, I knew it would not be long before it pooped. I'm just glad it didn't strand me on the way to work.
Unread 12-14-2013, 07:08 AM   #3
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
You won't be disappointed. My 32RH slipped between all 3 gears for the longest time. I figured out that manually shifting didn't allow the trans to slip. So since I was shifting for the trans anyway, why not add a lower first gear and an overdrive? I'm surprised you didn't opt for the 6 speed.
Look into the Toyota first gear swap for AX15s. Good luck!
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 08:26 AM   #4
joesseabee
Will do. I replaced synchros in my son's YJ so I'm already familiar with the ax 15. The only downsides were I cracked the 5th gear removing it, and the transfer case adapter was busted from a rusty mount, which I tigged.. it's holding up fine after 2 years.
Unread 07-07-2014, 04:07 PM   #5
joesseabee
My AX15 is bolted in, mostly. I just need to find a starter bolt, and drill the crossmember for the new mount location. Should be test driving it by the weekend.
Unread 07-07-2014, 05:25 PM   #6
MisfitSeven
MAiL Crawler.
Awesome! It really makes a huge difference going from an auto to a manual. You will easily feel more power. Great job.
You know what they say about great minds...
Mail crawling.
Unread 07-07-2014, 06:51 PM   #7
JBTJ
Normally going from an auto to a manual is a downgrade. But, in your case with the 42RLE, anything is an improvement.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 06:41 AM   #8
MisfitSeven
MAiL Crawler.
Any updates?
Unread 01-11-2015, 02:22 PM   #9
joesseabee
I finished the transmission conversion a few months back and followed up with a slipyoke eliminator and new driveshaft. It's been running great, just a little expensive on gas as a daily driver. Very reliable and fun to drive.
Unread 01-11-2015, 03:03 PM   #10
MisfitSeven
MAiL Crawler.
Great to hear.
Mail crawling.
Unread 01-11-2015, 03:55 PM   #11
Orannis
That extra low first gear for the AX15 is very interesting indeed, I'm looking to swap up from my AX5 soon, and deeper gearing does not hurt those four squirrels at all!
Orannis is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 07:47 PM   #12
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Will the AX15 bolt to your 2.5L?...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 09:09 PM   #13
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Not directly. Needs a different bellhousing
RnEmOvr is offline   Reply With Quote Quick reply to this message
ax15 , conversion , manual transmission
