im buying a lift real soon, check inside and if you have either lifts please review - Page 3 - JeepForum.com
post #31 of 38 Old 12-08-2010, 08:37 PM
Wrangler19
4in RC series 2, . I have it and i hate it.
1998 4cyl TJ, 4in RC series 2 lift, 33x12.50 BFG KM1's.
[QUOTE =inglisleslie;11598716]we only care about 4BT...jeep is run by slow people now who like plastic everything [/QUOTE]
Wrangler19 is offline
post #32 of 38 Old 12-08-2010, 08:54 PM
EricsGreen98Tj
^^^If you have the 2.2Shocks then change em out for somethin softer and your RC kit will ride better. A budy put F/R BIllsteins on his 4" X flex and loves it now. He hated it B4
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #33 of 38 Old 12-08-2010, 09:39 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
I have the Rough Country 4" lift. A lot on here will tell you its a crap product, and perhaps years ago it was. I can tell you from my personal experience that the RC 4" kit is of good quality, and there is nothing wrong with it. The only complaint is that the shocks are a wee bit stiff. Not over the top stiff, but you will notice it.
VA3IPB
The only True Professional Mechanic in the Greater Toronto Area for Modified Jeeps, and trucks. If Rock Spyder hasn't seen it before, or done it before, you don't need it.
TheHeretic is offline
post #34 of 38 Old 12-08-2010, 09:53 PM
StvDiego
I had a 4" RC Series II, it is no longer on the Jeep. For a budget lift it wasn't all that bad. A little harsh for awhile and it eventually settled in. That lift is now under a friend's Jeep with Bilstein shocks and it rides much better. For the price (dirt cheap on eBay) it was a decent buy.
So what do you plan on doing with the Jeep and why do you want a 4" lift? Are you after the look, do you plan on off-roading (how much and what terrain), is it a DD... These the right questions to ask first, or, what lift works for what I plan/need/want/budget.
For instance, while the Currie arms are the best the reality is that if you're not going to use them to their potential why spend $800 on just arms when you can get an entire lift that will meet your needs for the same price like the ones you mentioned that work just fine for a lot of Jeepers.
StvDiego is offline
post #35 of 38 Old 12-08-2010, 09:58 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
^^^^ Good advice.
VA3IPB
post #36 of 38 Old 12-08-2010, 10:31 PM Thread Starter
RustBeltCrawler
it is a DD for me, I already have 4" skyjacker springs that I got insanely cheap ($100 for all 4) and Im slowly piecing my lift together......I want to go 4" with 33's cause there isnt anything around here that you wont get through with that....I had a 4" with 33's two YJ's ago, it was unstopable around here, alot of people under estimate the 4" but it can get you really far as long as you build your rig right..........right now im really just lookin for control arms, the rest will fall into place
RustBeltCrawler is offline
post #37 of 38 Old 12-08-2010, 11:11 PM
StvDiego
In that case I would seriously consider spending some money on Currie control arms (check with Gerald at Savvy for pricing, he usually runs great deals). Bar none you will not find better nor be disappointed, it is money well spent.
StvDiego is offline
post #38 of 38 Old 12-09-2010, 12:00 AM Thread Starter
RustBeltCrawler
ok cool...ill have to check them out tomorrow, thanks
iron rock long arm , rough country 4" lift , suspension , zone lift kit
Buying Used Axles-What to Check? krazymatt TJ Wrangler Technical Forum 17 09-18-2010 11:45 AM
What to check for when buying a used np231 w sye? dbx11 TJ Wrangler Technical Forum 2 06-25-2010 09:06 AM
2000 4.0 TJ coolent leaking-what to check before buying a water pump? dequity TJ Wrangler Technical Forum 4 03-05-2009 06:02 PM
OME lift is on.... review and questions kenn YJ Wrangler Technical Forum 4 05-05-2005 11:50 AM
Hello and Can you check out my Product Review awjeep TJ Wrangler Technical Forum 1 06-07-2002 07:13 PM
