Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE
Best place to buy Rubicon Express! Don't Fear the Jeeper!Insane Rough Country Deals Call for more Info!!! so insanBarnes 4WD Universal 4 Link Kit
Go Back   JeepForum.com > Models > Wrangler Forum Group > TJ Technical Forum
Jeep Registry Register Blogs FAQ Mark Forums Read Search Members
Old 08-27-2002, 08:28 AM   #1
stark
iinstallation of 3"lift
i was debating between a rancho 2.5"lift ..a teraflex 3" lift..or a old man emu 2.5"lift...
i would like to install the lift myself..
are there any specialty tools needed that i might have a hard time getting or cost alot.
how long approx would it take to install the lift a weekend?
i've never done a lift before so please help me out and let me know if i should just have an offroad company install it or if it's easy enough i can do it
thanks
i have a 97 tj w/ manual tranny
stark is offline   Reply With Quote
Old 08-27-2002, 10:44 AM   #2
gatorfish
plenty easy to do. All you need is a good set of sockets and wrenches and other basic hand tools (BFH), 2 tall jack stands, a good floor jack, some level concrete and a friend.
'99 XJ RE3.5
past:
XJs '87 '91 '00
TJs '01 '02
gatorfish is offline   Reply With Quote
Old 08-27-2002, 12:11 PM   #3
Deathdealer
This is a fairly easy installation. It should only take around 6 hours, mine took 10 hours to do by myself but I spent a lot of time getting the bushings off the old shock bolts as my new shocks didnt include the lower shock bolts. (Damn Chrysler for epoxying the bushings to the bolts).
Be sure to blast all the bolts ahead of time (24 hours) with a penetrating lubricant (such as WD-40 or PB blaster). It will also be easier if you enlist a friend to help you with the project.
I found a nice writeup for the Old Man EMU but they are all basically the same at this size lift They are a bit over precautious in the writup but it pays to be and may save you time and money down the road if something breaks while your doing the install. Either way its a good idea to take a look so you can see what your getting into with the pictures and what type of tools you need etc. Enjoy!
http://www.off-road.com/jeep/reviews/oldmanemu/index2.html
[B]-DD[/B]
Black '98 TJ 4.0 Sport, Teraflex 2.5", JKS 1" BL, Currie 1" MML, Dana 30/Ford 8.8, AA HD SYE, Teraflex QD, Teraflex Oil Pan Skid, Skid Row Steering Box Skid, Poorboy Front & Rear Bumpers (w/ Swingout), JCR Offroad Rocker Guards, Garvin Trail Rack, Borla Header, 305/70/16 BFG MT/KMs, [B]-Go Bruins![/B]
[B]Black Jeep Club #666[/B]
Deathdealer is offline   Reply With Quote
Old 08-27-2002, 02:47 PM   #4
Jeepchik
You might think about gettin some spring compressors it makes the job alot easier
[B]Green Jeep Club Member #1[/B]
[URL]www.JeepHorizons.com[/URL]
Jeepchik is offline   Reply With Quote
Old 08-27-2002, 04:44 PM   #5
stark
thanks for the info leaning towards an old man emu system ..good price for the quality
Old 08-27-2002, 05:12 PM   #6
insaner
where should I look for pricing/buying lifts?
[URL=http://porc.purdue.org]Purdue Off-Road Club[/URL]
[b]Green Jeep Club Member #3[/b]
insaner is offline   Reply With Quote
Old 08-27-2002, 07:08 PM   #7
Jeepchik
you can go to any of the offroad parts store websites and price them, here are a few
www.4wheelparts.com
www.quadratec.com
www.4wd.com
www.performanceproducts.com
www.acmejeepparts.com
Or most of the lift manufacturers have their own website that will direct you to where you can purchase them....hth
Old 08-28-2002, 06:02 AM   #8
'drack
You might not need them, but it's better to have 'em on hand than run out in the middle of the install. Most places will "rent" them for free. They charge ya a deposit and then refund it when you return it. I only needed them for one coil and that was only because my stands weren't tall enough to allow enough droop for the axle.
Keith
[b]'00 TJ with some stuff[/b]
'drack is offline   Reply With Quote
Old 08-28-2002, 07:24 AM   #9
gatorfish
get some high quality, tall jack stands and spring compressors arent needed.
'99 XJ RE3.5
past:
XJs '87 '91 '00
TJs '01 '02
Old 09-03-2002, 02:36 PM   #10
tjjohn
It is going to take a good amount of time to do the lift, especially if you are not farmilier with vehicle suspension systems. I turn wrenches for a living and it took me 14 hours. hungover in 100 degree weather with no help and a phone that would not shut up. I also added an adjustable front track bar steering stabilizer and a pitman arm that took me two hours to remove, I actually broke two pullers trying to take it off, thats right I broke two freakin pullers, and I had never seen a puller break. the third one worked, lol. if there are a few tools I would make sure to have on hand it would be a drift pin a 3 lb hammer, a pickle fork if you are changing your track bar and a pitman arm puller. the spring compressor really starts to help at the 4 inch hieght but you can get away without it. it is not too hard to do but some things take a little work to line back up corectly. When you do the transfer case drop, support the transmission via a floor jack and a block of wood ( avoid metal to metal contact ) remove the nuts on the transmission mount, and then drop the belly pan this will save you lots of agrivation trying to line the pan back up after your put the spacer in, that would also be a good time to install the shifter drop bracket since the pan is out of your way. I could babble on for hours, I learned everything the hard way. Good luck
tjjohn is offline   Reply With Quote
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Technical Forum 10 03-06-2010 02:43 PM
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Technical Forum 5 12-13-2009 06:26 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Technical Forum 30 11-25-2009 12:13 AM
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
