Ignition Woes - Please Help! - JeepForum.com
post #1 of 9 Old 09-05-2010, 04:41 PM Thread Starter
jeepdude101
jeepdude101's Avatar
Ok, I'm at my wits end on this one and need assistance please.
When I turn the ignition key, sometimes the starter engages right away, and sometimes there is a couple second delay between the time the key is turned to when the starter begins to engage. Sometimes it takes 2 or three turns of ignition key for starter to engage.
Troubleshooting steps thus far:
Lights and instrument panel come on fine when key is turned - no dimming on lights. All connections to alternator, starter and battery are clean and tight.
Starter was replaced yesterday - I thought the solenoid was bad - not so.
Alternator was replaced 5 months ago and is currently outputting about 13.64v (is this too low?)
I did notice some battery drain when the jeep is powered down. So today I replaced my Optima Red-Top to a new Yellow-Top today. Problem still exists.
I tested for battery drain by removing negative battery cable and putting multimeter on neg. terminal / neg lead testing - result is no draw.
Not sure what else to test or replace. Is my alternator the culprit by not putting out enough juice? Any assistance is appreciated.
R.
'98 2.5L - 'Chili Pepper'
3.5 Rubicon Express Standard Flex
33" BFGs w/Black Steelies
SYE/CV-DS
Carolina Rockshop Fab Bumpers
KC Daylighters and Hella 500s
jeepdude101 is offline
post #2 of 9 Old 09-05-2010, 05:14 PM
grignac79
1979 CJ7
Could be ignition switch. As my jeep has gotten older I find I have to be real careful as to the position as I can now remove the key in more than one position. I have had it started and check engine lights come on. I wiggle the key and the lights finally clear off. They do wear and could possibly be an issue. Try experimenting with the key and see what you find. I have a 2000 TJ with this issue.
grignac79 is offline
post #3 of 9 Old 09-05-2010, 06:02 PM
Curly5759
Check the connections at the Park Neutral Safety switch (auto) or Clutch switch. The switches could be getting worn.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
post #4 of 9 Old 09-05-2010, 06:21 PM
fishinjeeper
Curly
I would take a look at that also. however, if it is the neutral safety switch, then try starting it in neutral instead of park
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #5 of 9 Old 09-05-2010, 06:22 PM
fishinjeeper
it should start no problem in neutral if it is the switch
post #6 of 9 Old 09-06-2010, 07:58 AM Thread Starter
jeepdude101
Amazing - I took a 20 amp fuse from slot 18 (spare) and dropped it into slot 20, which deactivated my neutral safety switch and problem solved! I cannot believe a simple fuse solved the issue. I never cared for having to push the clutch to start the motor anyway.
Grignac - my ignition switch is acting the same way, replacing it was going to be my next step if bypassing the neutral safety switch didn't solve the problem.
Thanks to everyone for their suggestions!
SYE/CV-DS
post #7 of 9 Old 09-20-2010, 01:38 PM
cadeucsb
jeepdude..your PM box is full fyi. Quick question...
I am curious why this would deactivate your neutral safety switch. Wouldn't installing a new fuse just ensure proper operation?
I am curious because I am going to try the same. Every couple starts my tj takes a couple chugs to get going, even if i prime the fuel pump. Never multiple key turns though...figure a fuse is a cheap try at a fix.
cadeucsb is offline
post #8 of 9 Old 09-20-2010, 01:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by cadeucsb View Post
Quick question...
He has a manual transmission, only automatics use neutral safety switches. His issue was his clutch interlock switch was not working properly when he stepped down on the clutch. Inserting the #20 fuse bypasses the defective clutch safety interlock switch that few except the mentally challenged need anyway. The #20 fuse circuit was added by Jeep engineering to allow the Jeep to be started without stepping on the clutch by inserting a fuse. A fuse is not normally in that slot.
Jerry Bransford is online now
post #9 of 9 Old 09-20-2010, 01:51 PM
cadeucsb
Got it, re-read it after your clarification and I see that now. On my auto I have a similar Park/Neutral Position switch on the same F20 fuse...worth a shot at the same test or am I in a different ballgame with the auto tranny?
cadeucsb is offline
alternator , ignition , problems , starter
89 YJ with ignition woes! frstjeepman YJ Wrangler Technical Forum 17 06-28-2010 10:50 AM
ignition randomly turns on after jeep is turned off and ignition locked karthac YJ Wrangler Technical Forum 3 01-12-2010 08:35 PM
Ignition woes... USMC_JeepGuy YJ Wrangler Technical Forum 12 05-28-2009 09:55 AM
Ignition cylinder woes!! Straight Six TJ Wrangler Technical Forum 6 02-26-2008 08:25 PM
88 4.2L Jeep Ignition woes Roadrnr28 YJ Wrangler Technical Forum 9 02-10-2008 08:28 PM
