Ignition switch problem. - JeepForum.com
post #1 of 7 Old 07-10-2010, 01:45 PM Thread Starter
0IIIIIII0
Last friday, I pull over to snap a photo, and when I try to start the jeep, the ignition switch won't trip. Ok, no problem, I think , must be a bad switch, and I get to work disassembling the column. I remove the whole column key assembly...lock cylinder, and various springs and pieces. I find the issue to be a broken metal piece that goes from the lock cylinder and into the ignition switch is cracked on the end. So, for the time being, I super glue it back together and get the Heep back on the road. It's been holding together all week.
Fast forward to five minutes ago. I call the jeep parts dept. and they tell me the ignition lock system is not serviceable and I will need a new column. Now seeing as I "serviced" it on the side of the highway, I call BS.
So now the question. Does anyone have a wrecked TJ that would be willing to tear in to the column to salvage this piece for me? There are no TJ's in the wrecking yards around me. I will post a photo when I break in there again so that I can be more specific about what I need.
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #2 of 7 Old 07-10-2010, 02:06 PM
Jonny Jeep
Jonny Jeep's Avatar
It's the ignition pin.
$75 from ebay.com or D A V E Y S J E E P S . C O M - Parts Specials look for the text STEERING COLUMN PROBLEMS?
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #3 of 7 Old 07-11-2010, 10:06 AM Thread Starter
0IIIIIII0
$75.00! goodness gracious. Looks like JB Weld for me.
- Samuel Adams
post #4 of 7 Old 09-10-2011, 08:33 PM
JeepSahara2001
Looks like it has been a year. Did the JB hold. I have the same problem.
Big Mark
[______]
(O||||O)
JeepSahara2001 is offline
post #5 of 7 Old 09-10-2011, 08:38 PM
leelum9
I got my set from rock auto...I think it was 35 dollars shipped
leelum9 is offline
post #6 of 7 Old 09-10-2011, 08:49 PM
leelum9
http://www.rockauto.com/catalog/more...2546988....not sure if yours is the same as a 97
leelum9 is offline
post #7 of 7 Old 09-10-2011, 09:31 PM
wrangler1997tj
I am having the same problem. Checked the starter and it is good. When yours was acting up, was it blowing the 30 amp big @$$ fuse in the engine compartment?
wrangler1997tj is offline
ignition pin , ignition , problem , issue , broke , broken , replace , lock cylinder
HUGE problem with '87 4.2L - Ignition Switch Power Issues (No power on key turn) jesseleikerjeep YJ Wrangler Technical Forum 11 02-26-2016 05:25 PM
Is this problem the ignition switch? Irishcopper TJ Wrangler Technical Forum 2 10-05-2009 07:18 PM
ignition switch to accessory position problem - say it ain't so! action jackson TJ Wrangler Technical Forum 1 09-30-2009 03:39 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-28-2009 12:02 AM
Starter/Ignition switch problem joedirt88 TJ Wrangler Technical Forum 7 11-15-2007 05:30 AM
