Ignition Switch Pin Actuator repair. - Page 3 - JeepForum.com
 1Likes
post #31 of 83 Old 12-04-2012, 07:30 PM
tommytj
Yeah, after going through this and learning how common this issue appears to be, I think I'm gonna grab one out of a junkyard for a few bucks as a backup. Now that I know what to do, it's about a 10 minute job to switch it out, so it'll be good to be prepared...I don't think it would be worth it to manufacture as there are so many of them available for cheap....
tommytj is offline
post #32 of 83 Old 12-04-2012, 10:41 PM
nickkick
Tommytj,
How much did the replacement cost you? Saw it online for about $80 and it's just a small piece of cast.
Would a junkyard piece be unreliable? How much was it from the yard?
Thanks
nickkick is offline
post #33 of 83 Old 12-05-2012, 04:15 AM
Richisinyoface
Richisinyoface's Avatar
My junkyard piece was 3 dollars and it has been in for a few years now
Just Empty Every Pocket.......yup they are empty all right.................
NRA Life member
Sienna Jeep club member #65
Richisinyoface is offline
post #34 of 83 Old 12-05-2012, 06:06 AM
Spaceball
In this thread there's a list of cars you can rob the actuator from. I grabbed a couple from Neons when I replaced mine.
http://www.jeepforum.com/forum/f9/20...59/index2.html
Spaceball is offline
post #35 of 83 Old 12-05-2012, 06:40 AM
GilaMtnJeep
GilaMtnJeep's Avatar
Originally Posted by nickkick View Post
Tommytj,
Thanks
I bought one at NAPA for $46
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #36 of 83 Old 12-05-2012, 07:56 AM
tommytj
Yeah, I bought mine replacement from NAPA for $46....
tommytj is offline
post #37 of 83 Old 01-03-2013, 07:39 AM
Ratm
I'm having a problem with my gauges. They work when my key is in the start position but once I let the key return to on they go dead. If I take my key a twist it slightly to the start position they come back on and work fine. Just wondering if its the pin or the actual key cylinder
Buy a Hybrid... My Jeep needs the gas!
Ratm is offline
post #38 of 83 Old 01-03-2013, 12:32 PM
Jonny Jeep
Jonny Jeep's Avatar
If the Jeep starts the ignition switch actuator pin should be fine as it's turning the switch all the way. I'd suspect the switch. I'd remove the switch and turn it with a screwdriver to see if it behaves the same. You'd be able to see the pin with the switch removed so could take a look at that at the same time.
Jonny Jeep is online now
post #39 of 83 Old 01-03-2013, 12:39 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
It could be the pin but more likely the switch itself. It is similar to what the guy in post #6 had but a different set of contacts. One set of contacts in the switch works the cluster & is supposed to power the cluster through fuse 10 in the block behind the glove box when in start & run. It apparently is not maintaining contact in the run position. The switch is not part of the key cylinder. Look at the video in post #1. Replacing the switch is the same procedure as the actuator pin. When you have it apart you can check the pin to see if it is cracked but if it looks good I would say the switch needs replacing. (Not a bad time to do the pin as a preventive measure.)
Edit: Jonny you are too quick! & a very good way to test it.
Rubi4MyMrs is offline
post #40 of 83 Old 01-03-2013, 02:36 PM
Ratm
Is there a difference in the switch for auto and manual? I see it on quadratec but it says for auto
Ratm is offline
post #41 of 83 Old 01-03-2013, 03:21 PM
Jonny Jeep
Jonny Jeep's Avatar
The switch should be the same for auto or manual. You could have a look in the parts lists linked in my sig to double check.
Sent from my ST27i using JeepForum
post #42 of 83 Old 01-03-2013, 04:43 PM
Ratm
That link isn't working for me
Ratm is offline
post #43 of 83 Old 01-03-2013, 04:55 PM
cheftrail
i pulled mine out of a neon wreck, dude at the junk yard said i could have it for a cigarette!
05 TJ locked & loaded, 04 WJ DD, 96 XJ and a darn Volvo V70
cheftrail is offline
post #44 of 83 Old 02-20-2013, 06:08 AM
maroonTJ01
Thank you
Originally Posted by Benderff View Post
When I searched I found tons of people with the same problem. I wanted to post the video Dorman made for the fix. The nut gobblers at the dealer will say you need to replace the whole steering column. Lucky for us Dorman did a little research and helped us out.
I started the Jeep up heading to work, and thought the key turned funny. After the other crew left at shift change I went to move the Jeep since my station doesn't have enough parking spots when both crews are there. I turned the key and nothing happend. The rotation was off as well.
To pull it apart you will need
Phillips screw driver.
T-10 Security bit (center hole).
T-20 bit.
Driver for above bits.
When I pulled it apart I found one of the stupidest designs ever.
Broken part and Box (number) for replacment from NAPA.
In a jam you could start your rig with a flat head screw driver once the above part is out.
Promo video from Dorman with step by step instructions.
http://youtu.be/W5m31g0-3wI
http://www.youtube.com/watch?v=W5m31g0-3wI
I hope that helps the next poor sucker that gets stuck someplace.
This helped me tremendously!! I was having an issue where my TJ would intermittently start (new battery, no corrosion on cables, etc) & it really had me stumped. I started thinking it had something to do with the ignition and after searching for a bit I came across this threat. My actuator pin looked just like yours, with the metal broken off at the "tip". I went to NAPA with the part number you posted and $46 later, I had the part & got it fixed!
Also just wanted to add that I tried using a flathead screwdriver to start the jeep by inserting it into the black ignition switch just fot sh!ts & giggles (while I had everything apart I figured why not?), and IT WORKED!! I thought that was pretty cool.
Again, THANK YOU to the OP ...my fiance will now be much happier with the Jeep now, lol
2001 Sport 4.0, 5-speed
D30/D44, 31x10.5 BFG KM2 Mud Terrains on stock 15" Canyon wheels
KC lights
maroonTJ01 is offline
post #45 of 83 Old 07-07-2013, 08:47 AM
rEDFiSH
OK, so I'm hoping someone with experience might be able to help me out with a puzzle
I went to start my '04 TJ yesterday, but the key would not turn far enough forward to start the Jeep. The key easily turns to accessory and run positions, but not to start. So I assumed either the actuator pin or ignition switch were failed. The actuator pin did not appear broken, so I tried turning it with the lock cylinder while everything was disconnected from the steering column; it turned and the Jeep started normally. I reassembled everything, and tried again. No go. The key will not turn far enough forward. So, I took the lock cylinder back out and inspected the inside, and everything looks fine (nothing broken or worn).
I thought about buying a new ignition switch and actuator pin assembly just to rule that out, but I would not think either is the problem since it functions when removed from the steering column. The lock cylinder does not appear broken, but I don't really know what a bad one would look like
Does anyone out there have any thoughts or suggestions on how to proceed?
rEDFiSH is offline
Hot Air Again! Blend Door Actuator Repair Savvy TJ Wrangler Technical Forum 41 10-26-2016 01:26 PM
Ignition Switch Actuator Pin Repair jdgrip TJ Wrangler Technical Forum 2 04-13-2012 10:28 PM
Ignition Switch Actuator Rod Mistry YJ Wrangler Technical Forum 4 09-05-2011 10:56 AM
Ignition Actuator out...Push Button Start? sstump TJ Wrangler Technical Forum 1 06-12-2011 08:59 PM
Ignition actuator pin roughknight69 TJ Wrangler Technical Forum 1 12-08-2010 05:18 PM
