Ignition switch acting funny - JeepForum.com
post #1 of 14 Old 07-03-2013, 06:48 PM Thread Starter
cairopd1069
I bought the 2000 Wrangler Sport a couple of weeks ago. The PO said if the A/C would not blow, just wiggle the key. Sure enough, we were going down the road and the A/C quit blowing, I wiggled the key and it started blowing again. I also noticed the factory radio would not keep correct time and would always go back to AM when the Jeep was turned off. Today, I wiggled the switch and the radio appeared to turn off and then came back on in the AM mode. Any suggestions? If the ignition switch needs to be replaced, how hard is it and what are the steps to replacing it?
Any help is appreciated.
I know some of you hard core Jeep owners wonder why I need A/C, but we drive the Jeep to Church and I don't want to show up at Church sweating, the preacher might think I've been up to something!!
I will lift up mine eyes to the hills from which cometh my help. My help cometh from the Lord.
cairopd1069 is offline
post #2 of 14 Old 07-04-2013, 10:38 AM
Jonny Jeep
Jonny Jeep's Avatar
Having to wiggle the key probably means the ignition switch is bad. Deos anything else drop out at the same time?
The radio not being able to keep memory likely means it doesn't have a constant supply from the IOD fuse. Do courtesy lights work they run off the same fuse.
Jonny Jeep is offline
post #3 of 14 Old 07-04-2013, 12:55 PM Thread Starter
cairopd1069
Yes the courtesy lights work. The radio is the only thing I know I am having problems with. It is possible that the radio is bad. Any advice on replacing the ignition switch? I'm sort of "mechanically inclined", but not a full blown mechanic. If the steering wheel needs to be pulled, I'll probably pay someone to do it.
post #4 of 14 Old 07-04-2013, 04:58 PM
Benderff
Benderff's Avatar
Here you go. http://www.jeepforum.com/forum/f9/ig...epair-1378503/
Benderff is offline
post #5 of 14 Old 07-05-2013, 01:38 AM
T-Jay
T-Jay's Avatar
I've had the same problem...intermittently since I bought my TJ. But my switch only malfunctions at start up. When it does, my airbag light comes on, my A/C doesn't work and my reverse lights don't work. My stereo works fine though. All it takes is a gentle turn of the key forward while the motor is running. Once I do that I hear a light relay clicking sound. After that, everything works properly. I'll replace the switch sooner or later. Probably after the damn thing finally dies entirely...in the middle of the woods at dusk
T-Jay is online now
post #6 of 14 Old 07-05-2013, 02:28 AM
Jonny Jeep
Jonny Jeep's Avatar
Since the courtesy lights work the constant supply should be there. It's possible it either isn't connected to the radio or the switched and constant power are connected the wrong way round at the radio. Radio needs pulling to check that though.
post #7 of 14 Old 07-05-2013, 05:02 AM Thread Starter
cairopd1069
I was wrong about the courtesy lights, the only way the dome light will come on is if you turn the h/l switch to make it. It does not come on when you open the door.
post #8 of 14 Old 07-05-2013, 05:43 AM
Cuder
Look at fuse #4 behind the glove box, it deletes the dome lights when the doors are off and it's probably been pulled. As far as your other problem, I would replace the ignition switch.
My Build Thread:
Cuder is offline
post #9 of 14 Old 07-05-2013, 06:06 AM Thread Starter
cairopd1069
I did not know there was a fuse panel behind the glove box. I will look this afternoon. Thanks
post #10 of 14 Old 07-05-2013, 03:14 PM Thread Starter
cairopd1069
I am kind of confused after reading the posts and the posts that some referred to. My Jeep starts and runs fine. No trouble at all starting. So I'm confused as to what part I might need to replace. The ignition switch or the pin?
post #11 of 14 Old 07-06-2013, 09:33 AM
sc00bz
It would not be the actuator pin. If it breaks, you just can't start the jeep without some creativity. I'm not sure beyond that. However, if you take the route of replacing the ignition switch, I'd go ahead and replace the pin too. The pin breaks at the most inconvenient time (usually... Mine broke in my driveway after running errands. Ha). That way you have a spare and probably won't have to worry about it for a long time.
97 TJ with some stuff.
sc00bz is offline
post #12 of 14 Old 07-06-2013, 10:26 AM Thread Starter
cairopd1069
Okay, I'll try the ignition switch. The PO had pulled the fuse for the courtesy lights, so I still have the radio problem, but I would probably be better off to replace it with an aftermarket model. I am going to pull it and make sure the ground is grounded securely.
post #13 of 14 Old 07-06-2013, 06:30 PM
Cuder
IGNITION-OFF DRAW FUSE
All vehicles are equipped with an Ignition-Off
Draw (IOD) fuse that is removed when the vehicle is
shipped from the factory. This fuse feeds various
accessories that require battery current when the
ignition switch is in the Off position, including the
clock and radio station preset memory functions. The
fuse is removed to prevent battery discharge during
vehicle storage.
When removing or installing the IOD fuse, it is
important that the ignition switch be in the Off position.
Failure to place the ignition switch in the Off
position can cause the radio display to become scrambled
when the IOD fuse is removed and replaced.
Removing and replacing the IOD fuse again, with the
ignition switch in the Off position, will correct the
scrambled display condition.
The IOD fuse should be checked if the radio is
inoperative. The IOD fuse is located in the Power
Distribution Center (PDC). Refer to the PDC label for
IOD fuse identification and location
The Ignition-Off Draw (IOD) fuse is removed from
Power Distribution Center (PDC) fuse cavity 25 (Fig.
6) when the vehicle is shipped from the assembly
plant. Dealer personnel must install the IOD fuse
when the vehicle is being prepared for delivery in
order to restore full electrical system operation.
REMOVAL
(1) Turn the ignition switch to the Off position.
(2) Unlatch and open the cover from the PDC.
(3) Remove the IOD fuse from fuse cavity 25 of the
PDC.
(4) Store the removed IOD fuse by inserting the
terminal blades of the fuse into the empty fuse cavity
27 of the PDC.
(5) Close and latch the cover onto the PDC.
INSTALLATION
(3) Remove the stored IOD fuse from fuse cavity
27 of the PDC.
(4) Align the terminal blades of the IOD fuse with
the terminal receptacles in fuse cavity 25 of the PDC.
(5) Use a thumb to press the IOD fuse firmly down
into PDC fuse cavity 25.
(6) Close and latch the cover onto the PDC.
Check this fuse to make sure it's getting good contact.
My Build Thread:
Cuder is offline
post #14 of 14 Old 07-06-2013, 07:40 PM Thread Starter
cairopd1069
Cuder, that is some great info!!! I will look at that fuse tomorrow. I appreciate it very much.
