Ignition Key Issue - JeepForum.com
post #1 of 1 Old 03-28-2011, 10:00 PM Thread Starter
DannibusX
Ignition Key Issue
Hello folks, I been searching this section of the forum for most of the day looking for a fix for this issue. I have an '03 TJ and the key keeps working itself loose as I drive down the road. It'll pop out a bit and kill the stereo and I have to push it back in to get it to work again.
Anyone familiar with this and fixed it? I'd rather avoid the expense of a locksmith if it's fairly simple.
Thanks in advance!
1986 CJ7, 4.2L I6, Carter BBD, Rancho 2.5" Lift, Team Rush.
Coming soon: Exhaust, Wheels and Tires, Axle Gearing.
DannibusX is offline
TJ Ignition Cylinder issue CLynn85 TJ Wrangler Technical Forum 0 03-06-2011 10:28 AM
Is this an ignition module issue? racerx8413 YJ Wrangler Technical Forum 5 09-15-2009 07:49 PM
Wet Ignition Issue wsroman TJ Wrangler Technical Forum 0 08-01-2009 09:59 PM
Ignition Issue or bad key?? chico166 JK Wrangler Technical Forum 17 12-06-2007 05:56 PM
ignition issue help! jeep795 YJ Wrangler Technical Forum 4 06-03-2006 05:54 PM
