Ignition issues !!! Please Help me - JeepForum.com
post #1 of 2 Old 09-20-2010, 04:54 PM Thread Starter
Firejeep1989
Hey all so i have a 200 Jeep Wrangler with the 5 speed manual. This morning my jeep was completely fine. When i parked for no more then two minutes and went to go start it up, when i turn the key to the on position (not start) there is a single beeb noise and the gauge cluster (which sometimes comes on after the beeb) and anything else that electric in the vehicle does not work. Then when you rotate the key to start it completely shuts down everything. I tried jumping it and no luck. Also i have check all of the electrical connections to the starter and the alternator
any ideas ?????
Firejeep1989 is offline
post #2 of 2 Old 09-20-2010, 05:05 PM
wushaw
Rockin jeep
wushaw's Avatar
Clean your battery terminals is the first thing you should do then move on to testing the battery.
wushaw is offline
ignition
Ignition Issues Dwatts5250 YJ Wrangler Technical Forum 0 09-09-2009 03:54 PM
Help!!! Ignition issues Chris_24 YJ Wrangler Technical Forum 4 07-30-2009 06:31 PM
Ignition issues! Need help with poltergeist JK. buckeyeocean JK Wrangler Technical Forum 2 07-30-2009 09:51 AM
92' ignition issues! val92wrangler YJ Wrangler Technical Forum 0 08-11-2008 11:42 AM
Ignition issues? YCP4x4 TJ Wrangler Technical Forum 3 09-18-2005 06:16 PM
