Quantcast If I went to 33" tires on 04 Rubi would I need to change gearing? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > If I went to 33" tires on 04 Rubi would I need to change gearing?
Old 09-24-2009, 08:53 AM   #1
Hammockman
I'm planning a 2.5 suspension lift and 1" body lift and then going to go with 33" tires on my 04 Rubicon. Would I need to change the gearing to keep it a daily driver?
Not all treasure is silver and gold, mate!
Hammockman is offline   Reply With Quote
Old 09-24-2009, 08:54 AM   #2
blubaru2002
No "need to"
blubaru2002 is offline   Reply With Quote
Old 09-24-2009, 08:57 AM   #3
TNeustadt
TNeustadt's Avatar
Her's a chart showing performance expectations/ loss Tire & Gear Ratio Chart at Morris 4x4 Center
TNeustadt is offline   Reply With Quote
Old 09-24-2009, 08:59 AM   #4
Dmcastino
Nope, I have 33" tires and 4.10 gears just like you do and I'm perfectly happy with it.
Dmcastino is offline   Reply With Quote
Old 09-24-2009, 08:59 AM   #5
randy8
know a guy that is running 37s on stock gears in his rubi and he can still take my 4cyl in a race and i have 31s
randy8 is offline   Reply With Quote
Old 09-24-2009, 09:04 AM   #6
coach-mike
I have 33 with 373 something and 3"lift and it rides great. 10 mpg though. I am going to do a 6" lift this winter with 35 and go with 456
coach-mike is offline   Reply With Quote
Old 09-24-2009, 09:12 AM   #7
Gymguyjeep
I have been driving my 04 Rubi on 33's for almost two years. I live where it is pretty flat so most of the time it works out pretty good for me. When I travel to New Mexico and Colorado where there are lots of mountains, it doesn't have the power I would like to have. I kinda like the effect of the 33's on the gearing in the NVG241OR transfer case when on trails in 4LOW. The stock 31 tire size made the 4:1 4Low ratio a little too deep for me. You certainly won't hurt anything by running 33" tires with the 4.10 axle ratio, but don't expect the highway driving on anything but flat road to be as good as it was before. If you don't think you can live with the Rubi on 33" then save for a gear change at a later time. I think that I will eventually go to 35" tires and realize that I would not want to live with the stock gearing at that point and will need to be prepared to go to a 4.56 or 4.88.
2004 TJ Wrangler Rubicon - 5.25" Total Lift, Antirock, Various Skids, Winch, 35" MT tires, Roof Rack. Matching Off-Road Teardrop Trailer.
1993 XJ Cherokee - 3" Lift, 31" tires
Previous Jeeps - 1981 CJ-5, 1985 CJ-7
Gymguyjeep is offline   Reply With Quote
Old 09-24-2009, 09:16 AM   #8
Alexia
The NV3550 has a 0.78 final gear.
Third chart down: Experimental Insanity! - Jeep Gear Ratios
It is a difference of about 150rpm at 65mph. 33" tires will be fine with the stock 4.11 gearing.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Build Project Thread
Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ
Alexia is offline   Reply With Quote
Old 09-24-2009, 09:22 AM   #9
Imped
TITS
Imped's Avatar
Gears are never a NEED item. But when you move up to larger tires, your final drive ratio is essentially higher (lower numerically). So, you're on 31's and 4.10's right now, which is perfect with your 5 speed. When you go to 33's, it will feel like you're on 31's with 3.73 gears, still a very good ratio for both on and offroad. I've driven 4.10's with 33's and it's perfectly fine. 4.56 is the "ideal" ratio but 4.10 won't leave you begging, especially with the 4:1 low range you have.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 09-24-2009, 09:32 AM   #10
Deacon
Purveyor of Funk
Deacon's Avatar
You realize that your speedometer is under-reporting, now, right? So if you're going 75, for instance, it'll only show you going 65. That means the Jeep thinks it's gone fewer miles, so if you do the trip mileage divided by pump amount, it's going to look like you're pumping more gas to go fewer miles. You're right about 10% off with your setup. And yes, it's perfectly drivable (I had the same setup).
Why not go 4.88? Yes, 4.56 will get you back to stock ratio, but your tires and such are going to be much heavier (probably the rest of the Jeep, too, if you armored it up), and a little lower gear ratio (higher numerically) will help spin things along nicely. And with the extra weight of the Unlimited, I think a little extra would be nice Just something to consider.
Deacon is offline   Reply With Quote
Old 09-24-2009, 09:47 AM   #11
Unlimited04
Unlimited04's Avatar
it will be tolerable.
Unlimited04 is offline   Reply With Quote
Old 09-24-2009, 10:37 AM   #12
Imped
TITS
Imped's Avatar
Too high and undergeared.
OlllllllO
Float Test Build
IndyORV
Best served cold
Old 09-24-2009, 12:10 PM   #13
Hammockman
Thanks for the information
That's kind of what I expected but it's good to get feedback from people who have gone with that set up. When I get the cash and the time I'll do the lifts and tire changes then see how I like it.
Old 09-24-2009, 01:31 PM   #14
alexr40
nop. specially if you have 6speed...
1998 Jeep Wrangler 2.5L Turbo @8psi (haltech)
Locked Front & Rear, 4.56s, 4:1 low range with 2LO.
2.5" RC Lift with 1.25" BL & MML on 33s TSL Boggers with Beadlocks.
Ironman 9500 Winch, ARB Snorkel, Warn Bumpers/rock sliders/gas tank skidplates..
Smittybilt Tube Fenders, Axle tube seals, braided brake lines etc.
alexr40 is offline   Reply With Quote
Glock Forum
