If i'm miss fireing that should set off the OBD light right? - JeepForum.com
post #1 of 3 Old 12-10-2009, 01:51 PM Thread Starter
Tmsnake1
My 04 Rubicon started shaking violently at stop lights, idle and so on last night. While moving and at higher speeds it sounds kind of odd and I can feel that something is not right, but its at a standstill when you can hear and feel something is completely wrong.
I'm assuming its either a broken motor or trans mount or I'm miss fireing. Problem is, is that its Zero here in chicago and my hood is literally frozen shut at the moment.
I would think if I'm miss fireing that it would set off a light correct?
I have no check engine light.
2002 Wrangler Sport - destroyed by drunk!
2004 Wrangler Rubicon -Yellow, 5spd
I
Tmsnake1 is offline
post #2 of 3 Old 12-10-2009, 02:00 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Take it somewhere to check it out yourself(heated garage at someoe's house).Motor or transmission mount would take 5 minutes to check.Sometimes codes don't go off.What do you hear and feel at a standstill?Misfire you can hear from the back when someone revs the engine.
TheBoogieman is offline
post #3 of 3 Old 12-10-2009, 02:05 PM Thread Starter
Tmsnake1
It's really hard to tell because the damn thing is vibrating everything on the inside that it is difficult to pinpoint. I got out and listened from the back and it doesn't sound bad. It also doesn't seem like its lost any power. I'm hoping its a mount!..
I
Tmsnake1 is offline
Help needed 2.5L stumbling and back fireing with surging, INTERMITTENT PROBLEM Bojeepus YJ Wrangler Technical Forum 10 06-17-2009 08:08 PM
Check Engine Light On/ Has A Miss scooter_60 TJ Wrangler Technical Forum 4 10-12-2008 11:08 AM
4.0 still has miss??? 4wheelscott YJ Wrangler Technical Forum 3 04-13-2006 08:48 AM
Fireing Order? Please HELP OddManOut YJ Wrangler Technical Forum 1 07-22-2001 10:54 PM
Fireing Order? Please HELP OddManOut YJ Wrangler Technical Forum 0 07-22-2001 10:31 PM
