Idling issues after dead battery - JeepForum.com
post #1 of 3 Old 01-25-2010, 10:24 AM Thread Starter
Iamjr
I had a dead battery a month or so ago and had to jump start my rig and after it ran for a few minutes it would'nt idle. I rev it up and it would run fine but soon as i let off the gas and it came to a idle it would die. I unhooked the positive side terminal off the battery for a few seconds hooked it back up, started it and everything seems to be fine. It idles like normal now. Just yesterday the battery was dead again and same thing happend again. Is this normal and you have to unhook the battery to maybe reset everything or what??
Iamjr is offline
post #2 of 3 Old 01-25-2010, 10:47 AM
jurob
when the battery dies or you disconnect your battery for a amount of time the eec reverts back to its factory settings. it needs a short time to relearn.
i would clean your throttle body and iac. when the eec resets it needs the time to relearn your dirty idle air controller. factory settings assume clean iac and thats why you get the bad idle till it relearns.
jurob is offline
post #3 of 3 Old 01-25-2010, 11:20 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
My bet is on your battery being so dead or nearly dead that it's not putting out enough power to provide the alternator its required +12v exciter voltage. The alternator uses 12v from the battery to power its circuitry inside, at least on the type of alternator used in our Wranglers.
Like if you entirely removed the battery while the engine was running, which you should not do, the engine will eventually die. A good charged up battery is required for the engine to run properly.
Getting
Jerry Bransford is online now
battery dead ....argh... dual battery setup???? asjeep TJ Wrangler Technical Forum 21 07-20-2009 06:46 AM
Dead battery chainsaw620 TJ Wrangler Technical Forum 5 06-22-2009 06:24 PM
4.0 idling issues WVjeep94 YJ Wrangler Technical Forum 13 01-23-2009 03:09 PM
Weber Idling Issues hguffman YJ Wrangler Technical Forum 2 01-20-2005 01:03 PM
Idling issues jsandmel YJ Wrangler Technical Forum 3 10-07-2004 04:47 PM
