idler pulley - JeepForum.com
post #1 of 3 Old 07-18-2010, 06:10 PM Thread Starter
440forPOWER
idler pulley
Hello, I plan on throwing on a new belt on the 4.0l and was curious how hard is it to replace the idler pulley why I'm in there? Do I have to remove much to get to it? is it a one bolt deal? Any help would be greatly appreciated
440forPOWER is offline
post #2 of 3 Old 07-18-2010, 06:34 PM
yarmish
It is just one 15mm bolt. Take you about an extra 3 minutes while changing the belt
In a ZUK now....
yarmish is offline
post #3 of 3 Old 07-18-2010, 06:45 PM
alecmcmahon
Like stated above, it takes about 3 minutes to replace, one bolt... Piece of cake.
Might as well do it when your doing the belt , its cheap enough and easy enough to put in with your preventive maintenance.
Does it click, squeel or have some play in it that worries you?
alecmcmahon is offline
serpentine belt , idler pulley removal
4.2L Idler Pulley oct7brian YJ Wrangler Technical Forum 10 02-12-2006 10:32 PM
Idler Pulley vertresq YJ Wrangler Technical Forum 5 12-29-2005 07:46 PM
Idler Pulley CJO TJ Wrangler Technical Forum 1 11-24-2005 09:53 AM
Idler Pulley kixinc YJ Wrangler Technical Forum 0 11-16-2005 04:26 PM
Help...idler pulley, P/S pulley, serpentine belt? BaltimoreJeep YJ Wrangler Technical Forum 23 02-17-2005 02:33 PM
