Idle problems....need help - JeepForum.com
post #1 of 6 Old 07-17-2010, 11:15 PM Thread Starter
kinz384
ok i was gonna get my jeep inspected and wasnt sure if they would do it with check engine light on ( torque converter) so i took the positive lead off battery to reset it.
i guess i didnt tighten it down good enough, when i tried to start it, it wouldnt crank and all the gauges went crazy. so i took it off and put back on real good.
now it started but its running crazy high now. in park its at 2500 rpm, and at idle in drive its at 1100 rpm. what could be the problem? and whats the normal rpm it should be at. will it hurt to drive it?
thanks
kinz384 is offline
post #2 of 6 Old 07-17-2010, 11:22 PM
freeskier93
Well, if the check engine light was on because of the torque converter I would start their. I don't know how it works in Texas, but in Colorado when you go to emissions, they put the car on a dyno and connect the OBD computer to their computer. It use to be if the CEL was on automatic fail, but know they since they hook the computer up they can tell what codes are popping up and won't fail you on stupid things like PCM reset. In other words if you probably would have failed if because they would still see the code in memory.
Reseting the computer can also sometimes cause idle problems.
freeskier93 is offline
post #3 of 6 Old 07-17-2010, 11:26 PM Thread Starter
kinz384
well they dont check emissions for just an inspection. ive had torque converter looked at and was told need a new one and tranny rebuild. wasnt worried about codes and stuff just wasnt sure that if they saw the light on, if they would pass it. so i reseted it.
kinz384 is offline
post #4 of 6 Old 07-17-2010, 11:32 PM
freeskier93
Why are you getting your car inspected? Usually only during registration and emission testing does it need to be done. Is it a salvage title your trying to get reversed or something?
As far as your problem goes, check you IAC, Idle Air Control.
post #5 of 6 Old 07-17-2010, 11:42 PM Thread Starter
kinz384
? in texas you have to have it inspected every yr. what am i checking with the IAC?
kinz384 is offline
post #6 of 6 Old 07-18-2010, 12:22 PM
freeskier93
Interesting. In Colorado you only have an "inspection" when you have to do emissions testing.
This is a picture of the throttle body. Check the IAC for clogging and give it a good cleaning. In the picture the left side is towards the front of the jeep.
high , idle , inspection
idle problems!!! aviles TJ Wrangler Technical Forum 3 08-14-2009 03:39 PM
Idle Problems with 4.2L SHJeeper YJ Wrangler Technical Forum 9 01-25-2009 10:57 AM
idle problems KeyserGogo TJ Wrangler Technical Forum 9 09-30-2008 07:24 PM
Idle problems. RPM's low at idle. rocknjeep YJ Wrangler Technical Forum 6 08-16-2008 07:54 PM
Idle problems black93delsolsi YJ Wrangler Technical Forum 3 09-04-2003 04:24 AM
